![]() | Home > Maintenance & Mods (L322) > LR set to recall all 2011MY FFRR's for new AGM battery |
Mudplugger Member Since: 20 Feb 2009 Location: err... near Inglewhite, Lancs. Posts: 95 ![]() ![]() ![]() |
Just to reinforce Jasperoony's post a few days ago, (in post titled "First Problem with my 2011"):
AMV Member Since: 09 Mar 2011 Location: EU Posts: 152 ![]() ![]() |
Is this only for the UK? Or a worldwide recall? |
Don't shoot the messenger! I'd not have published this if I didn't believe it to be factually accurate, and I'm just confirming what was stated by others earlier.. As for why LR are keeping this quiet (although it's interesting you've had a mail from your dealer) - you'd better ask them. I'm not wonderfully pleased with LR myself just now, especially since many of the issues the 'fix' is supposed to cure are happening on my 2009MY. The issue with mine appears to be caused by a major current drain fault and not just an inadequate battery/design issue. Muddy Range Rover Vogue SE SDV8 - L405 (now sadly sold) BMW i3 (fantastic little runabout) Kioti NX6010 Tractor Yamaha Big Bear ATV And a whole heap of other kit... |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 742 ![]() ![]() ![]() |
Sorry Muddy, I wasn't having a go at you, i'm just disappointed not to have had any communication from LR |
I really hope so ![]() |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
some one's head will roll for this fiasco
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
Bet it will be kept very hush hush and given a fancy name!!! |
p-trax Member Since: 30 Dec 2010 Location: Hertfordshire Posts: 261 ![]() ![]() ![]() |
I have to agree with Jez, the overly protective attitude of LR just |
Trust me, they are better than some. BMW still won't admit a fault in their CBS system that causes brake pads to squeal when they have about 14,000 miles to go. Take the sensor off, the squeal goes. Had 4 cars with the same system, same problem at same interval. System still in production... Sensors off, warranty void. ![]() |
Gerry do you have a letter from LR about the issue ? 2021 P400 Silicon Silver AB Gone 2011 Bournville TDV8 VSE Gone 2008 Black Canadian HSE LUX |
No Jez, i don't.
This is interesting as AGM batteries don't give you many benefits over a "Flooded Lead Acid" battery.
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
mines been doing this but then it is a bmw version....and to add my old e60 did this as well plus it had battery issues "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back ![]() |
This is taken from a Wiki page on AGM batteries:
