Home > Technical (L322) > Fuel Burning Heater Retrofit |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 890 |
Well I was going to get this on the bench today but suffered a fsr fault last night so investigated that instead. Found the main 12v feed wire burnt in the connector plug so new fsr and plug on order. A job for next week I managed to do a temp repair, also connected my ctek charger in the boot fuse box and plugged it in to my outside power supply just behind my car.
23rd Jan 2021 7:13pm |
Hopefully going to get back to this some time this week I'm making up a loom so I can bench test it and use the same loom on the car via the remote.
25th Jan 2021 8:19pm |
Just a standard 12v remote switching relay currently programmed to latching mode
26th Jan 2021 8:31am |
31st Jan 2021 12:35pm |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 |
I have one of those boards. Very good quality and work exactly as they should No7 - 2003 V8 Vogue |
31st Jan 2021 4:51pm |
Yep, I saw your retro fit post didnt you connect it up to the petrol tank as well ? The boards have a link you can short for either derv or petrol. I dont fancy dropping the tank to connect to petrol but am happy to fit the small bottle I was planning to use from the start |
31st Jan 2021 6:11pm |
You don’t have to drop the tank. The fuel pump assembly has a dip tube fitted from factory. You just have to nip the end off and connect on to the stub. No7 - 2003 V8 Vogue |
1st Feb 2021 6:33am |
Arh makes sense, will keep that in mind if the additional derv bottle becomes an issue.
1st Feb 2021 11:33am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3067 |
This is interesting:
1st Feb 2021 5:30pm |
I have now recieved my anologe circuit board for my fbh install. I will still be running this up on the bench before retro fitting it, I coulda done with this with the current weather.
9th Feb 2021 1:45pm |
How did you get on with this in the end?
28th Nov 2021 12:52am |
Iv still got this sitting here on my todo list, I bought a board to replace the existing one in the fuel burning heater and it can run it on petrol or derv. I looked at fitting the fuel pipe from the tank but it seems much easier and safer to use a separate small diesel tank engine bay mounted. All switchable from a remote |
28th Nov 2021 8:23am |
I had a look at my car today. I’ve got the plug in the boot for the receiver but due to it being bloody cold I didn’t look under the bonnet.
28th Nov 2021 9:03pm |
It needs a pump, iv got everything sitting here I just didn't get round to fitting it due to major engine overhaul. I will try and find some time to run it all up on the bench. Iv got the power connector in the wheel arch and iv fitted a fuse in the correct place to test power. I really have no excuse not to fit it all.....except its bloody cold. There just ain't enuff hours in the day |
28th Nov 2021 10:00pm |
