Home > Technical (L322) > Fuel Burning Heater Retrofit |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8503 |
Hmm, wonder how big a job that would be??
2nd Jan 2021 11:00pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3067 |
I did wonder about that.
2nd Jan 2021 11:03pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 890 |
Iv been thinking of a fbh retrofit to my 4.4 v8 petrol lpg, simple fbh none w-bus on a simple on/off remote. My understanding from research on here is the fbh runs on derv or petrol. I was thinking simple derv feed from a small supply tucked away somewhere fed via the pulse pump they require.
2nd Jan 2021 11:22pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
I must admit, this did cross my mind when I've been faffing around with mine. Although no FBH valve or screen display it does have the wiring for it.
3rd Jan 2021 10:26am |
Well there are a few of us interested in this so as were heading for another lockdown I think I will make a start I'm shut down any ways cant go to work under the current tier system any ways
3rd Jan 2021 11:16am |
Iv been messaging a breaker on the bay and explained what I'm after doing, he has an l322 v8 him self and loves the cars soooo.....he is going to remove the complete fbh, fittings n hoses for me from a td6 and ship them down to me to have a play with.
4th Jan 2021 7:50pm |
Sounds like a good idea.
4th Jan 2021 8:11pm |
No sorry I dont know any one with a petrol set up but iv read somewhere in my research all about it think it mite have been an old post on here let me see if I can dig it out.
4th Jan 2021 8:16pm |
Best description iv found so far about the fbh
4th Jan 2021 8:31pm |
Interesting, I can see why you're going the diesel route.
4th Jan 2021 9:16pm |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 |
You will find all the electrics are already in place including the aux heater fuel pump. You should have the dip tube as well unless the main tank pump has been changed for a after market unit as these don’t always have these fitted. On the plumbing side, you will need a change over valve, arious hoses and bulkhead fitting, the heater itself and carrier and the remote receiver and fob. No7 - 2003 V8 Vogue |
8th Jan 2021 8:23pm |
Thanks i will have a look at this to see ifs it's in place, I agree the electrics mite be but unsure I will find a pump. The change over valve I'm aware of but it wasnt my intention to fit one. Iv got lpg connected and I'm planning on rerouting one of these hoses into and out of the fbh.
8th Jan 2021 8:31pm |
Just had a play with the on board aux fbh control iv never paid much attention to it but I set it for 5 mins ahead to come on and go off 20 mins later, well it all works just need a fbh now |
8th Jan 2021 9:11pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
My 2004 Autobiography Petrol V8 has a petrol FBH. happy to let someone have a look if they are near Bristol way!
8th Jan 2021 10:26pm |
