![]() | Home > Technical (L322) > Fuel Burning Heater Retrofit |
RR_05_US Member Since: 25 Jan 2022 Location: up north Posts: 15 ![]() ![]() |
yep, Thermo top C
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 ![]() ![]() ![]() |
I Would ditch all the timed stuff, you can trigger a countdown timer relay connected directly to the Thermotop. I use a Sim card Garage opener. SO I just call it in the morning and it comes on for 30 mins. I have posted a thread about this a while back. L322 2007 TDV8 3.6 |
I don't need the timer but as far as I know the OE Webasto unit needs to communicate to the car via the K-bus anyway. Otherwise you can't even switch it on nor by a Telestart remote neither by a GSM trigger. The HEVAC model needs the connection as well to open the extra water valve and switch on the blower to heat up the cabin. |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
You should now have AUX Heat and Vent appear on the screen if it has updated if not I would do a battery reset thats what I had to do before it came on the screen. |
the park ventilation screen was already there before I started to set up the fbh. I can program the timer and ist works as it should but without switching on the Webasto unit. When I push the "manual" button on the screen nothing happens just the button got a red surrounding to show it is switched on. it seems to be the head unit doesn't send the correct message to the K-bus. Will try to play with the settings on the weekend. |
Do you have the remote key module in the boot ? or even the three wire plug that it would normally connect to...? L322 2007 TDV8 3.6 |
yes, when I installed the Webasto unit I also added the remote box. When I use the remote the Faultmate shows me the Webasto unit receives the signal from the box but nothing happens. |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 937 ![]() ![]() |
I think you should start a separate thread about this as it's nothing todo with my original. |
In deed it could make sense to open a new thread. Maybe I will do so when I know what to do next.
