![]() | Home > Technical (L322) > Fuel Burning Heater Retrofit |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3201 ![]() ![]() ![]() |
They do…
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 986 ![]() ![]() |
Am revisiting this thought it about time, iv got some time off over Xmas and iv still got all this kit sitting here in a box.
Be interested to see how you get on!
B100 Member Since: 06 Jun 2017 Location: Bedfordshire Posts: 31 ![]() ![]() ![]() |
KDS2 - you ask if the Webasto can pump its own fuel. The answer is no. Webasto supply a cylindrical solenoid pump which pulses at variable rates according to the fuel need at the heater. Hence it is controlled by the PCB in the heater. No other pump is needed. If at all possible, the simplest approach is to fit a new pick-up fuel pipe into the top of the tank.
The impending new lock down means I will have time on my hands to dabble |
RR_05_US Member Since: 25 Jan 2022 Location: up north Posts: 15 ![]() ![]() |
Hello from Northern Germany.
I know the answer to this 1, you need to reprograme the heating control panel for fuel burning heater or just swop it out for 1 that is all ready programmed. As I suspect you won't be able to do either I suggest you fit the canbus override board and activate the fbh via remote control.
Thanks for the quick reply.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1317 ![]() ![]() |
Is this info any good for you guys with L322?
good idea, but this won't work without having the park heater connected to the car network. The remote needs that as well as the touchscreen timer. |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
I had park heating enabled on my 2004, it has to be enabled in three places look on Gap diagnostics web site for the information it can take 24 hours for it appear on the screen, mine still hadnt after 3 days so I did a battery reset then it popped up on the screen. |
@kds2
Sorry I just printed the information off Gap site then armed with the info asked OFG here in Lincoln that have the Gap full tool to do it for me as I don't have the Gap iid, I believe it can be done with the basic tool. |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 ![]() ![]() ![]() |
Which Webasto do you have… ? Is it a thermo top C ? L322 2007 TDV8 3.6 |
