Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 656 |
It would be great if there was a fault code Cass.
7th Jun 2020 4:36pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 732 |
My mistake I thought yours was the same P023 fault mine had.
7th Jun 2020 5:38pm |
RRTDV83.6 Member Since: 22 Oct 2020 Location: Devon Posts: 8 |
Did you ever get to the bottom of this second one? Mine has a similar lag, I notice the commanded boost never goes above 83% during driving conditions, I have found it revs much quicker on low down rpm with the electric actuators disconnected and held in the 100% position. Does anyone else see 100% commanded boost low down? Cheers. |
22nd Oct 2020 10:38pm |
I thought I'd figured it out last Tuesday. I fitted a pair of new MAF sensors and it drove great until the weekend when I filled up then back to driving crap.
6th Nov 2020 4:20pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
Fuel tank venting problem or brand of fuel? |
6th Nov 2020 8:18pm |
I think it was sainsburys fuel so possibly. Will need to fill up today but its never made a difference it the past.
7th Nov 2020 8:55am |
gruodiz Member Since: 09 Dec 2011 Location: LT Posts: 10 |
Focus on port deactivation swirl flaps if they are permamnently closed or vacuum valve is always open so activate it to close 4 ports out of 8
16th Dec 2020 8:52pm |
Normally flaps are open, closed when activated by vacuum. I disconnected vacuum supply (red) pipe to actuators (blue). Vacuum was present at supply when engine was just started but then later was cut with engine still runing at idle, probably off by valve at front of the engine under vacuum pump near aux belts. Small piece of blue nitrile glove showing vacuum present. Blanked it with other bent hose. You could try to drive with pipe disconnected and blanked.
16th Dec 2020 11:55pm |
gruodiz, did you notice any difference when driving with the hose disconnected and blocked? |
17th Dec 2020 10:06am |
Yes, looks like car pulls better. Going to compare on dyno with and without it. |
17th Dec 2020 8:31pm |
Thanks.
18th Dec 2020 11:08am |
Did you read transmission and engine codes from your brohers car?
18th Dec 2020 11:28am |
Sansonneche Member Since: 20 Sep 2020 Location: 23 Posts: 5 |
Been reading through this thread from the beginning. The other common denominator is the driver- maybe an exorcist would help
8th Jun 2021 9:27am |
Cypriano Member Since: 17 Jun 2024 Location: Gdynia Posts: 1 |
Hi,
17th Jun 2024 8:36am |
