Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose
Page 19 of 19 <123 ... 171819
cass
I thought the same until I had the fault code written out, 5K plus miles later it is still running well. Not an ideal solution but if all else fails?
Post #556797 7th Jun 2020 3:50pm
MarianaWestminster
It would be great if there was a fault code Cass.
As far as its concerned all is OK. Multiple specialists say nothing is wrong. I've tried all the suggestions from the kind contributors on here.
Nothing works.
I sold the first tdv8 and bought another one as a dramatic way to fix the problem but it seems to have followed me to the new car!
My wife pointed out that I've worn the leather where I hold the steering wheel... must be how hard I grip it with anger.
Post #556809 7th Jun 2020 4:36pm
cass
My mistake I thought yours was the same P023 fault mine had.
You certainly get the top spot in the “how unlucky can I be” competition
Post #556825 7th Jun 2020 5:38pm
RRTDV83.6
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Nothing works.
Did you ever get to the bottom of this second one?
Mine has a similar lag, I notice the commanded boost never goes above 83% during driving conditions, I have found it revs much quicker on low down rpm with the electric actuators disconnected and held in the 100% position.
Does anyone else see 100% commanded boost low down? Cheers.
Post #570698 22nd Oct 2020 10:38pm
MarianaWestminster
I thought I'd figured it out last Tuesday. I fitted a pair of new MAF sensors and it drove great until the weekend when I filled up then back to driving crap.
I just put up with it now 🤷‍♂️ until I can afford to move up to an L405.
Post #571998 6th Nov 2020 4:20pm
GraemeS
Fuel tank venting problem or brand of fuel?
Post #572009 6th Nov 2020 8:18pm
MarianaWestminster
I think it was sainsburys fuel so possibly. Will need to fill up today but its never made a difference it the past.
I cant be bothered with it anymore. I drive it to work and back during the week and use my 1982 ford granada at weekends.
Post #572044 7th Nov 2020 8:55am
gruodiz
Focus on port deactivation swirl flaps if they are permamnently closed or vacuum valve is always open so activate it to close 4 ports out of 8 Question
Post #576403 16th Dec 2020 8:52pm
gruodiz
Normally flaps are open, closed when activated by vacuum. I disconnected vacuum supply (red) pipe to actuators (blue). Vacuum was present at supply when engine was just started but then later was cut with engine still runing at idle, probably off by valve at front of the engine under vacuum pump near aux belts. Small piece of blue nitrile glove showing vacuum present. Blanked it with other bent hose. You could try to drive with pipe disconnected and blanked.
BTW it is 2008 RRS
Post #576411 16th Dec 2020 11:55pm
GraemeS
gruodiz, did you notice any difference when driving with the hose disconnected and blocked?
Post #576424 17th Dec 2020 10:06am
gruodiz
Yes, looks like car pulls better. Going to compare on dyno with and without it.
Post #576477 17th Dec 2020 8:31pm
GraemeS
Thanks.
My brother has a MY08 3.6 RRS that's forever going into limp mode to the extent that he restarts it on the run even going uphill towing his van! I'll pass on your trick to see if that has any effect on his problem.
Post #576511 18th Dec 2020 11:08am
gruodiz
Did you read transmission and engine codes from your brohers car?
Where’s MarianaWestminster ?
Post #576513 18th Dec 2020 11:28am
Sansonneche
France 2009 Range Rover HSE TDV8 Santorini Black
Been reading through this thread from the beginning. The other common denominator is the driver- maybe an exorcist would help Laughing
Seriously, I was looking as I noticed that one of the short (intercooler/boost) pipes at the back of the engine going to the manifold on my V8 was very oily, and very occasionally get transient "engine system fault" message so thinkingI might have a leak. Looks like it might be bit of a pig to change, so anyone got any advice? And anyone know what the part number might be (can't find it in my Rimmer bros book (2008 vCool?
Thanks, Mark Mark
3.6TDV8 HST, Santorini Black
Yam 350 Bruin quad, mud coloured
Post #596801 8th Jun 2021 9:27am
Cypriano
Poland
Hi,
It's an old topic, but I read it several times, while investigating my P023D-22 issues (RRS TDV8 3.6). Most of the symptoms match my case.
I think I went through every advice in this thread, checked or replaces all the stuff. The engine fail frequency was reduced, but the problem remained (just harder to reproduce).
After latest unsuccessful fix, I have decided to take non-standard approach. I checked the vacuum lines for leaks - just by checking by hand the vacuum was there, but I wanted to do a test.
Using manual vacuum pump, I tested parts of the vacuum system, and found out that the there is a leak in engine mounts part of the circuit. (it seems to be the same setup for RRS and RR)
I did a quick test using endoscope to see how the swirl flaps operate (as it is also easy to check the expected state in live data).
As a result I noticed that with the leaking mounts line, the swirl flaps were moving slowly, with several steps to fully close, opposed to a results with blanked engine mounts part, where the flaps actuator were moving quick and smooth.
So I left the engine mounts line blanked, and took the car for a test drive (watching live values).
The MAF reading were still quite different for each bank, but this time the MAP were different too.
In other words in low revs going up a hill (which I use for P023D-22 testing), the manifold pressure was much more inline with air flow than it was before.
So far no P023D-22, and it was 2 weeks ago (but as there were many times I thought it's fixed, I am still considering it under-testing phase).
One extra profit - with the vacuum leak blanked, the breaks work better (as the break booster has more vacuum) Smile
How I see it.
Engine has it years, new (factory reman) turbos, new intake manifolds, but the rest is old - injectors, cats (bank A might be restricted a bit - that's a side were exhaust manifold gasket had a leak), piston rings etc. So for sure it will not run as smooth and balanced as new.
Therefore I can imagine there can be some imbalance between banks. (injectors offsets still look quite OK all in 900-1100 range)
As under load the air flow varies between engine sides, the PCM closes the manifold tuning/balancing valve, and expects the manifold pressure to be correlated to air flow and turbo actuator position.
If the tuning valve electic-valve is opeartional, but the vacuum is to low to close the valve, the pressure between banks is being aligned (while it shouldn't be), the PCM can see it as a correlation issue throwing P023D.
After long fight I'd really like this "fix" to be the final Smile Cypriano
RRS 2008 TDV8 3.6
Post #694590 17th Jun 2024 8:36am
