![]() | Home > Maintenance & Mods (L322) > Oil removal 4.4L TDV8 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
You will be able to loosen the filter using a large adjustable spanner , but the advantage of using a socket is that you can use a torque wrench to ensure it is refitted correctly to 27 nM torque.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1306 ![]() ![]() ![]() |
Some thing to check when you change your filter. After the filter is removed take a look in the housing and you will see what I think is a piece of metal that acts as drain valve that opens when you loosen the filter. When you put the new filter in and tighten it down, the filter presses on it to close the hole.
Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 152 ![]() ![]() ![]() |
[quote="Solidtom"]Hi mike, Rob,
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Tom
Solidtom Member Since: 16 May 2020 Location: Paris Posts: 6 ![]() ![]() ![]() |
MISSION ACCOMPLISHED |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Bravo! |
Do we all agree that one “notch” is about 150mL? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
[quote="Baltic Blue"]Dave,
klj Member Since: 24 Aug 2019 Location: Frozen North Posts: 66 ![]() ![]() ![]() |
Hi. I got hold of the Sealey pump. Doddle. Ten minutes for oil and filter, spent longer waiting for the digital oil level sensor to wake up |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 296 ![]() ![]() ![]() |
Me too, thanks for all the tips fellas. 9.5 out and 8 in - leaving it to settle overnight before topping up.
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 ![]() ![]() ![]() |
Anyone got a photo from just a bit further away as not sure I'm looking in the right place. |
To the left of the oil filler cap. Picture above has the oil filler cap removed. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Agreed ![]() Definitely the best filling up policy is …8 litres, leave 5 minutes to settle then top up in 150ml cupfuls. Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
Overfilled again by garage on annual service despite requesting 8.25L only and then I will top up |
