Home > Maintenance & Mods (L322) > Oil removal 4.4L TDV8
Page 3 of 13 <123 4 ... 111213>
GGDR
Thx Nino - so are you saying you get more oil out using this additional drain point?
Where is that exactly?
Mike link to cheap AF-L here: http://www.fullfatrr.com/forum/post477980.html#477980
It arrived promptly and I'd order from them again.
10 litres for under £55 delivered.
The labels are German but otherwise legit!
Thumbs Up Thumbs Up Thumbs Up
. Cheers, Greg
Post #480054 3rd Jun 2018 9:26pm
GGDR
I went for dropping the oil. (see page 1 of this thread) For anyone thinking about doing it this way, it's pretty easy. There is an elbow on the end of the sucker pipe at the sump. The plastic pipe elbow is a finger squeeze and release from the sump pan. It's stiff but will come off with a little careful levering. Have a container ready!
The only thing tricky is it's hard to get back on. You need quite strong fingers to squeeze the tabs and using your other hand push very hard to get it back over a kind of barbed end. Measure the gap before removal and compare when you put it back.
But as oil changes go, very easy. Changing the air filters was more of a phaff than the oil change!
. Cheers, Greg
Post #480055 3rd Jun 2018 9:34pm
Baltic Blue
Greg,
Thanks for link.
I have ordered 10litres for my next service from them.
Post #480074 4th Jun 2018 7:12am
GGDR
Nice one Mike!
. Cheers, Greg
Post #480078 4th Jun 2018 7:41am
nino_nino
Greg, red is secondary drain plug and green (for reference) is vacuum drain pipe. as you have said, pipe is hard to get back on and frankly I'm not comfortable using that method on a regular basis, so much easier to vacuum as it is designed for doing it that way.
I use this wrench,
Nino,
ps.
drain is for LH and RH side turbo oil return pipe.
Post #480079 4th Jun 2018 7:41am
GGDR
As for engine oil volume, mine took 9 litres exactly after two top ups / re checks.
Here's my reading with engine at temp.
I'd previously bought a one litre bottle which I'd kept so the remaining litre kept in a correct AF-L bottle for top ups.. Not OCD at all.
Aliso aiming for 5-6 k changes to keep her sweet. Cheers, Greg
Post #480080 4th Jun 2018 7:44am
so we're still not absolutely clear whether the reading is correct when hot as specified in the WM , or when cold as per Ninos suggestion.. ... - .- -.
Post #480081 4th Jun 2018 8:13am
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Is the suction method what MDs use when servicing FFs? Obviously with the applicant engine type.
Just wondering if this is what can be done vs what should be done...i.e traditional oil change via the sump nut to remove any debris etc.
It suits me just fine the vacum method. Just leaves a horrid taste in your mouth for the rest of the day... Rolling with laughter 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #508053 9th Mar 2019 9:03am
Baltic Blue
I have sucked mine out 3 times now and always got out over 9 to 9.25 litres of hot oil.
I always clean out the filter housing, but have never found any sludge of any kind, but I am always a bit taken aback by how black the oil is, given that it has never done over 5k miles.
Post #508064 9th Mar 2019 10:01am
Shaun
England 2011 Range Rover Vogue 4.4 V8 Orkney Grey
Having done many oil changes on many cars over the years, I sucked 9 litres of oil out in a few minutes and certainly won't be going back to dropping oil out of the bottom!! 2004 TD6 - Gone
2011 4.4 TDV8
Post #508124 9th Mar 2019 8:18pm
DrRob
Mike
Is your vacuum pump the Draper one mentioned earlier on in thread?
Ta
Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #511706 11th Apr 2019 4:05pm
Baltic Blue
Rob,
Yep Thumbs Up
It is brilliant.
Because it holds 10 litres, you just get the oil hot and it sucks it out in a couple of minutes.
Post #511709 11th Apr 2019 4:13pm
DrRob
https://www.machinemart.co.uk/p/draper-man...extractor/
Mike - this one?
Does it need any modifications to the tubing to fit the vehicle extractor pipe?
I assume there is a plug on the engine extractor pipe that needs removing?
Do you use the manual pump on it? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #511716 11th Apr 2019 4:54pm
Baltic Blue
Rob,
Yes that is the one I have got and 100% recommend.
You just flip off the drain tube cap and the supplied pipe fits on directly without modifications.
Yes, I use it with the built in hand pump.
https://www.fullfatrr.com/forum/topic6052.html
See my entry on last page. ( page 294)
It really could not be any easier or cleaner to do an oil change.
Post #520840 6th Jul 2019 11:32am
DrRob
Thumbs Up Thumbs Up Thumbs Up Bow down Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #520855 6th Jul 2019 1:35pm
