Home > Maintenance & Mods (L322) > Oil removal 4.4L TDV8
Page 13 of 13 <123 ... 111213
Mfcetin
Germany 2011 Range Rover Vogue SE TDV8 Alaska White
Hi all,
I recently changed oil by disconnectiong the hose on the oil pan as described in WM. I am pretty sure I pushed in that quick connector as much as I could but It is very slowly leaking.
I guess there is o-ring in the quick connector which I could maybe replace? Does anyone know the size or a partnr for it?
thank you all 2011 Vogue SE 4.4 TDV8
Post #695904 10th Jul 2024 1:50pm
GGDR
not sure about part but I have removed and refitted mine quite a few times without issue. Maybe it's a bit dirty? Cheers, Greg
Post #695920 10th Jul 2024 4:53pm
NickS
United Kingdom 2012 Range Rover Autobiography TDV8 Orkney Grey
I recenty changed the oil on my TDV8 using a Euro Car Parts oil suction pump connected to the oil suction port within the engine bay part number 538771531 very simple process pump worked faultlessly & no need to crawl under the vehicle or remove any underbody trays etc. Good quality pump at a reasonable price & available off the shelf at Euro Car Parts.
Post #695930 10th Jul 2024 7:01pm
Mfcetin
In fact I only cleaned the oil pan side and not the hose. There might be some dirt.
The leak is not that bad so will wait till next oil change to clean it.
Thank you for the hint 2011 Vogue SE 4.4 TDV8
Post #695933 10th Jul 2024 7:05pm
Mfcetin
I dont mind crawling under the car and removing trays. It gives me chance to control if everything is ok 🙂
I know sucking method is described in WM but still feels like more oil comes out if I drain 😃 2011 Vogue SE 4.4 TDV8
Post #695934 10th Jul 2024 7:09pm
