Home > Maintenance & Mods (L322) > Oil removal 4.4L TDV8
Page 2 of 13 <123 ... 111213>
dolph34
I have an ebay job 24 pounds and takes about 2 mins or extract the oil. Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #479782 31st May 2018 2:00pm
@nino,
the owners manual says to get the oil to working temperature and then leave for 15 minutes so that the oil can drain down into the sump before checking the level .... ... - .- -.
Post #479783 31st May 2018 2:07pm
nino_nino
Mike, enjoy your bbg,
Stan, that's what I said, if you shut engine off at full working temp and come back 30 min. later the temp will still be at half mark. at that time oil level should be one notch below max. in the morning the oil level should be at middle mark or a notch above. (depending on the outside temp.)
I did this readings many times to establish oil level with cold engine, like in the morning. much more convenient, don't you think.
hot engine oil check is for the convenience of the dealership. Thumbs Up
Nino,
Post #479785 31st May 2018 2:41pm
nino, your post said ''wait minimum of 25~30 sec.'' ... - .- -.
Post #479787 31st May 2018 2:47pm
Baltic Blue
Land Rover certainly didn’t think very sensibly when they did away with the dipstick.
The last thing I want to be doing is playing with steering wheel buttons when my hands are dirty from changing the oil, but at least I was able to wash my hands, which I doubt many mechanics do every time they recheck the level.
I got over 9litres out, but put less than 9 litres new oil in. (I have never topped up the oil between services.)
Post #479793 31st May 2018 3:35pm
Baltic Blue
Nino my friend, you are a genius Thumbs Up Bow down
When I checked the oil level this morning before starting the engine it read exactly on the full line.
After getting it nice and hot, then leaving to stand for 30 minutes, I got the following;
Half a litre sucked out and now all correct.
Many thanks
Mike.
Also thanks to Adrian for the simple remedy to how to empty the siphon. Thumbs Up
Next time I am only going to fill with 8 litres of new oil. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #479869 1st Jun 2018 12:19pm
GGDR
Mike what is the size of that mega socket you've got on the filter?
Cheers, Greg
. Cheers, Greg
Post #479870 1st Jun 2018 12:42pm
Baltic Blue
Greg,
36mm 3/8th sq drive.
About £4 from Eurocarparts on one of their 75% bank holiday mega sales offers.
I bet you have been laughing at my fill it up, suck it out Saga.
Bring back the dipstick.
Mike.
Post #479873 1st Jun 2018 12:54pm
GGDR
Cheers Mike - no I agree - bring back the dipstick!
. Cheers, Greg
Post #479874 1st Jun 2018 1:02pm
Baltic Blue
Here is one on eBay, but if you wait for a Eurocarparts sale offer you will get it cheaper.
Post #479875 1st Jun 2018 1:08pm
Baltic Blue
I have re checked oil levels again this morning, both hot and cold.
Cold, ie before starting engine, 1 notch above half full.
Hot after run and leaving to stand on level ground for 30 minutes, 1 notch below full.
What really shocked me was just how black the 1/2 litre of new oil that I sucked out was.
I will definitely be changing it twice a year just to keep it “flushed out” even though it will probably only do 4 -5 K miles in between changes.
Post #480000 3rd Jun 2018 12:37pm
nino_nino
if you do ~4K mi. oil changes, she is going to Love You and respond in kind. this is what I bought for my lady -
60 L. of MOBIL 1 5W-30 ESP, paid 320 quid.
Mike, why don't You do short write up on measuring oil level on 2011 and up 4.4 TDV8 engines, then Stan can put that in the Wiki. Cold engine oil level is both easier and more precise then procedure recommended by WM. I believe that oil overfilling is contributing factor to O rings and oil cooler gaskets failing.
Nino,
Post #480002 3rd Jun 2018 2:23pm
GGDR
Mike I did mine recently but didnt suck it - I unhooked the suck pipe at the sump and dropped the oil. Possibly got more out as opposed to the suction method as I put in 8.5 litres and then needed a half litre top up.
EDIT: just saw higher up you got 9 litres out
. Cheers, Greg
Post #480003 3rd Jun 2018 2:37pm
Baltic Blue
Greg,
I got 9.25litres out , so unless it has been diluted by diesel doing DPF regens there couldn’t have been much left in?
When I re- filled with new oil, I initially put in 8 litres which read half full (cold) so I added a further 1/2 litre thinking that would be OK, but after running the engine for a few minutes to warm it up slightly, it read full .
Then Nino warned me to re- check the level when it had got to full temperature and I got the overfilled warning, so I have sucked out a further half litre and now cold it reads one notch over half and hot it reads one notch down from Max.
Conclusion,
I recon 8 litres is best as initial re-fill, get it hot, leave it to stand for 30 minutes, re-check level and add a cup full if needed to bring it up to near max “hot”.
Mike.
PS,
Please re- post or PM me details of where you got cheap Shell AF-L. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #480006 3rd Jun 2018 3:09pm
nino_nino
Greg, you will get same amount "sucking" or draining, there is second drain plug- right above crossmember pipe. I drain that every third oil change. it drains cc 1/2 liter.
Nino,
Post #480008 3rd Jun 2018 3:25pm
