Home > Maintenance & Mods (L322) > Oil removal 4.4L TDV8
Page 10 of 13 <123 ... 910 111213>
Solidtom
France 2011 Range Rover Vogue TDV8 Santorini Black
Thanks both of you
I will try to find a manual pump tomorrow and a 36mm socket eventually.
I will do my tests and let you know the output.
Cheers
Post #575192 5th Dec 2020 9:48pm
Baltic Blue
You will be able to loosen the filter using a large adjustable spanner , but the advantage of using a socket is that you can use a torque wrench to ensure it is refitted correctly to 27 nM torque.
Post #575193 5th Dec 2020 10:09pm
kevinp
Some thing to check when you change your filter. After the filter is removed take a look in the housing and you will see what I think is a piece of metal that acts as drain valve that opens when you loosen the filter. When you put the new filter in and tighten it down, the filter presses on it to close the hole.
When I did my first oil change this piece was displaced. It attaches on a plastic peg in the housing.
Post #575207 6th Dec 2020 12:10am
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
[quote="Solidtom"]Hi mike, Rob,
I have been trying the suction method through the engine tube today with a 12v oil suction pump
I think thats your problem right there. I use a hand vacuum tank type like most others on here that prefer this method and it works just fine. It still takes 10 minutes to get all 9+ litres out but its so easy. I just can't see a small electric pump creating enough negative head/vacuum.
Post #575223 6th Dec 2020 10:58am
rjff
Tom
You may be able to get one of these on the local 'bay
https://www.ebay.co.uk/p/21017015950
There are cheaper ones available but this is the Draper unit.
https://www.drapertools.com/product/77057/...-Extractor
I have a cheaper one at about 45euro, but it has a 9 litre capacity so needs to be emptied once part way through a removal.
HTH. Cheers
Richard
Gap IIDBT
Post #575229 6th Dec 2020 11:34am
Solidtom
MISSION ACCOMPLISHED Thumbs Up
It worked with the 12V vacuum. Ran the car and had the oil boiling hot with a 40mn drive, rest if for 10mn.
Extracted 9L over 20mn.
I did find the 36mm socket but need another am torque to make sure I torque to the exact 27nm.
Added 8.00L first and then re-checked and added additional 0.5L.
Tomorrow will go for a run to get that torque arm and finish work with the oil filter.
(Lesson for me the oil filter doesn’t help with the sucking but does the oil filter cap removed!)
Post #575274 6th Dec 2020 7:06pm
DrRob
Bravo! Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #575280 6th Dec 2020 8:18pm
DrRob
Do we all agree that one “notch” is about 150mL? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #592694 29th Apr 2021 3:21pm
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
[quote="Baltic Blue"]Dave,
https://www.fullfatrr.com/forum/topic52688.html
I was asked for this guide by another “sucker”.
Just shout if you need any more help.
Mike.[/quote
Bow down Thanks again Mike as refresher needed And I found this again!!!
Dave]
Post #597683 16th Jun 2021 10:12am
klj
United Kingdom 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
Hi. I got hold of the Sealey pump. Doddle. Ten minutes for oil and filter, spent longer waiting for the digital oil level sensor to wake up Censored ----------------
2010 RR tdv8 3.6 ( gone but not forgotten ...)
2012 RR tdv8 4.4
2004 RR 4.4 V8 (M62) -gone but not forgotten (sob)
1998 P38 RR - least said the better
2009 BMW 7 Series 3.0d
Various motor cycles - BMW GS
1998 Jag XKr 4.0 V8
Post #598029 19th Jun 2021 2:27pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Me too, thanks for all the tips fellas. 9.5 out and 8 in - leaving it to settle overnight before topping up.
Now to see how it goes on the Defender and it’s multitude of fluids.
Post #598616 24th Jun 2021 8:03pm
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Baltic Blue wrote:
Just pull off the black plastic bung and attach the drain tube... right next to the oil filler cap.
Anyone got a photo from just a bit further away as not sure I'm looking in the right place.
Post #600787 15th Jul 2021 8:48pm
DrRob
To the left of the oil filler cap. Picture above has the oil filler cap removed. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #600838 16th Jul 2021 8:23am
Baltic Blue
Agreed Thumbs Up
Definitely the best filling up policy is …8 litres, leave 5 minutes to settle then top up in 150ml cupfuls.
Post #600842 16th Jul 2021 9:00am
DrRob
Overfilled again by garage on annual service despite requesting 8.25L only and then I will top up Rolling Eyes
They've put 9.2L in as deducted from the dregs left over in the 5L container.
Showing overfilled warning message on cold engine after waiting 30seconds for sensor to settle reading.
I'll be sucking out later today Big Cry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #602186 29th Jul 2021 1:48pm
