![]() | Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4325 ![]() ![]() ![]() |
Great work 👍
tinribs Member Since: 23 Jun 2017 Location: UK Posts: 20 ![]() ![]() |
Any updates yet Michael?
michaelpalmer7 Member Since: 08 May 2015 Location: Bedford Posts: 21 ![]() ![]() ![]() |
Nothing yet.
Fat Lad Member Since: 13 Aug 2020 Location: Cambridge Posts: 18 ![]() ![]() ![]() |
As a fellow 'cooling only' FFRR owner I am interested in how that replacement peltier cell works out for you too Michael. I'll be stripping my seats in the near future but I have a list of issues of which this is not a priority yet!
So I’m afraid it’s bad news!
On a separate note I was just going through the wiring diagrams for the seats and the section on seats only seems to cover the standard ones with traditional elements.
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 147 ![]() ![]() ![]() |
Just ordered a lower seat climat assy. for US 49.99. |
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 ![]() ![]() ![]() |
I too have the cooling only for the driver seat, the passenger works fine and the codes for the drivers are right seat back and right seat. |
3.6RR Member Since: 11 Sep 2020 Location: Brighton Posts: 4 ![]() ![]() ![]() |
Did this work for you? |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
Am I correct in thinking, that there's 'two' heater units per seat? One at the back & one under the base?
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
There should be back and base units in your front seats assuming they have base and back heating and/or cooling.
Don't know yet. The unit arrived on Thuesday, will work on it on Saturday. If I compare the look and the numbers on the Jag unit with pictures of the RR unit I may be able to swap the whole heating assembly. ![]() |
The Jag units certainly seem easier and cheaper to come by so if someone manages to get one of those working then great.
So I took out the seat today and changed the Peltier-Part.
