Home > Technical (L322) > Where did that cloud of smoke come from?
Page 3 of 13 <123 4 ... 111213>
Roi354
United Kingdom 2005 Range Rover Vogue Td6 Buckingham Blue
I suggest next time you do a motorway run and force a regen you drop a gear and floor it.
On a previous BMW I had this would create a plume of smoke and instantly drop both soot and ash levels by a significant margin. I suspect the start/stop driving you've done in between have partially achieved this.
That BMW in question was sold with 204k miles last year and on the same DPF from new. I did have it 'professionally cleaned' (read - jetwashed on my drive) at around 120k due to failed thermostats not providing the correct regen condition.
Post #561246 13th Jul 2020 11:23am
GGDR
revs not needed or recommended for regeneration.
what you need is:
- cruise control,
- 50mph or more,
- fuel; more than 1/4 tank
- enough time
- IIDTool ideally so you can monitor
. Cheers, Greg
Post #561307 13th Jul 2020 6:27pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
When I got the DPF full warning on mine I headed out to the motorway from Gainsborough which is a torturous route through country lanes. I thought the motorway was best so I could get to a constant 60mph to give it time etc. The route through the lanes I was only driving gently to minimise soot build up, after approx 8 miles the warning went off, no need for the motorway, no need for revving it to death. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #561346 14th Jul 2020 3:25am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Having read much on here before I chose not to rev it to death either. I was though expecting to see a massive drop in the soot levels due to gas temps and running at a constant speed for longer than required according to the manual. I will be out in it again before it goes in for the smoke test which will mean plugging the IID back in and monitoring what's going on. Obviously that's not an ideal way to drive as I don't want to find myself fixated on where my soot levels are, what I need is to get the confidence that the car is doing what it's supposed to do 2011 TDV8 Vogue SE
Post #561358 14th Jul 2020 7:01am
AJGalaxy2012
In the 18 months I had mine, the orange warning came on only once. A lot of my driving is the worst kind for the DPF, typical journeys being 2 miles or less for much of the week. The system did seem to look after itself with no intervention other than that one occasion. BMW i3 Electric Car
Post #561360 14th Jul 2020 7:14am
dennij
My car is still currently in the garage having a fair few issues put right, managed to speak with them today and it would appear that one of my inlet manifolds has a small crack in it, not enough to show with a high pressure smoke test but enough to show a boost error when under load. So it seems that although rare so far, the inlet manifolds can have an issue with cracking. Hopefully this will be the end of my car trying to hide itself in a plume of smoke and save me a lot of embarrassment when it has decided to do it on more than one occasion. 2011 TDV8 Vogue SE
Post #565672 27th Aug 2020 1:57pm
Dolphinboy
@Dennij.
Thats exactly what happened to mine. Pax inlet manifold cracked. Being Plastic, they expand due to the high pressure of the turbos. Mine was £1600 to replace one - some say replace both at the same time as it's injector harness off etc.
All was well for several months but now have runaway regen demands (1800 in 10 minutes Shocked) which LR MD don't know how to fix! going in to LR indie next week.
I would suggest an oil change if your fuel/oil dilution is over 5%. Cant do any harm.
Post #565693 27th Aug 2020 5:12pm
dennij
Hi Dolphinboy, car is still with the garage, so far they have carried out the turbo drain mod and replaced the secondary turbo. Now the inlet manifold is being replaced along with oil change and finally an MOT. At this rate the repair bill is going to come to more than I paid for the car Big Cry 2011 TDV8 Vogue SE
Post #565743 28th Aug 2020 7:07am
DrRob
Why a new secondary turbo? I had mine changed a year or so ago as it was the source of one of my oil leaks (others were oil cooler and oil pump plug)...
Is it at Green Oval? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #565744 28th Aug 2020 8:26am
dennij
From what I have been told, the seals had gone. The garage in question won't fit refurbished units as they have had issues with these in the past so a new one was ordered and fitted. Car is at my local indy up here in Cumbria, he looks after both my Land Rovers and has always carried out quality work. 2011 TDV8 Vogue SE
Post #565757 28th Aug 2020 10:36am
dennij
Today I was finally able to collect my FF after spending almost 8 weeks at the garage. Initially it went in for a high pressure smoke test to see if they could find a reason why I would get this sudden smoke engulf the car and throw the red DPF message. Work carried out consisted of the turbo drain modification, a new second turbo (seals gone), the L/H inlet manifold (small crack)and all injectors removed and tested (all passed). The bill was eye watering and in reality, probably more than can be justified on a vehicle of this age and mileage but it is what it is and hopefully, all the issues I've been having should now be resolved. The return drive was only short but I was able to get the revs above 2,500 and there was no hint of smoke whatsoever, before I would have left a plume similar to Chernobyl so that's a positive start. I need to put some miles under it's belt now and see how it performs so will report back in a few weeks/months depending on what I find. 2011 TDV8 Vogue SE
Post #567132 15th Sep 2020 10:33am
DrRob
I feel your pain on the bill and I didnt have the turbo drain mod done Crying or Very sad
I stuck it on a 0% card
Hope it's all sorted Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #567134 15th Sep 2020 11:03am
dennij
Cheers Dr Rob, I'll keep the post updated either way, hopefully it'll all be positive from this point forward, I just need to get the confidence back with the car now so I'm not constantly looking in my mirrors every time I come to a stop waiting to see if the cloud of smoke is going to appear. 2011 TDV8 Vogue SE
Post #567135 15th Sep 2020 11:16am
dennij
Well I’m not sure that I’m out of the woods just yet. Took the car on a 150 mile round trip to check everything was ok, around 100 of this was on the motorway sitting at 65 with cruise set. I had the IID tool plugged in and was monitoring what was going on. The exhaust temperature sensors showed that the temperatures were rising indicating a regeneration was taking place, however, at best I only managed to drop 1g of soot from the DPF. According to the IID there have been no successful regenerations which makes sense as my grams reading gets to 20.8 then drops down anywhere to 19.6 at best. All this time the oil dilution rate is increasing meaning at this rate I will be doing an oil change every 700 miles or so. It’s as though the regeneration switches off but the temps continue to rise, up to 620c on one sensor, plenty of heat to burn off the soot so not sure why it’s not happening. The smoke on acceleration above 2,500 has gone and the DPF isn’t filling up at the same rate it was before so I guess that’s something. Not sure where to go with it now.
Picture shows results when I parked up at home.
 2011 TDV8 Vogue SE
Post #567486 19th Sep 2020 3:07pm
DrRob
I’d just run it around with the IID unplugged and if no DPF warnings then relax Thumbs Up
Monitoring it will send you loopy Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #567499 19th Sep 2020 6:24pm
