Home > Maintenance & Mods (L322) > Plastic sill removal. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4311 |
I’d say nobody had been there before me since it was built. I’m on home holiday this week so just doing it slowly every morning before the sun comes round and roasts me in my black boiler suit Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
22nd Apr 2020 10:57am |
I put these on a few months back but they’ve not kept the lip clean enough for my liking as they don’t cover the width of the lip enough imho. Am going to fit Freelander 2 ones LR001623 (need 2) as part of current work Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
22nd Apr 2020 11:02am |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 |
This is an FL2 one, installed:
22nd Apr 2020 12:50pm |
Got a pair from Steve Parker LR via their ebay shop. About £21 delivered. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
22nd Apr 2020 1:21pm |
107SW Member Since: 03 Jan 2016 Location: Yorkshire Posts: 43 |
How easily please does the whole plastic liner come out ?
22nd Apr 2020 9:52pm |
ShuntL322 Member Since: 21 Dec 2019 Location: Acle, Norfolk Posts: 18 |
It’s a tough one to pull out. I had to peel it over the wing lip then drop it out. But it was a coldish morning in the workshop.
22nd Apr 2020 10:28pm |
Here’s how my 2002 looked after a quick scrub with the angle grinder an wire wheel. They were rusty. Bottom of the c post holed an about 6 inches on the sill near the jacking points.
22nd Apr 2020 10:33pm |
Thanks ShuntL322
23rd Apr 2020 7:22am |
There are also a couple of threaded studs welded to the wheel arch which the liner has to be flexed over to release it. It's quite tricky to do that as the edge of the liner also tends to catch on the lip around the arch itself. fanders --------------------------------------- 2009 4.2 SC Buckingham Blue 2021 Hilux 2.4 |
23rd Apr 2020 7:47am |
After. All painted up. Next to protect with waxoyl then Freelander 2 trims
23rd Apr 2020 11:33am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1258 |
I know many of you might disagree but my thoughts are not to paint over rust even if you've treated it. You only have to leave a tiny speck for it to start bubbling again. I prefer to use waxoil directly on the patch because it has active antirust protectors that soak into the surface. Be kind with any replies. |
23rd Apr 2020 9:06pm |
Kev - I’ve always painted over rust after rubbing down then applying a phosphoric acid based product like Jenolite or Kurust first. I then apply lots of clear Waxoyl over and regularly inspect and add more. My plan is to waxoyl the lip then add the Freelander 2 trims.
24th Apr 2020 7:00am |
That's good mate and I wouldn't disagree with how you're tackling it. Personal choice as you say. I've just had some U shaped rubber seal delivered which will cover the entire lip when the door is closed, so no chance of any stones hitting the metal work and it only cost me a fiver for 2 metres. I'm doing the whole rim in one piece with an angled cut in the centre to go around the kink. Cheers Kev. |
24th Apr 2020 7:21am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 693 |
Does one have a link to this? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
24th Apr 2020 7:43am |
