![]() | Home > Technical (L322) > 4.2 Supercharged V8 Issues |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1353 ![]() ![]() |
It won't run without the inlet manifold and maf installed, computer will say no....
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
Matt - have you half disconnected the gas?
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 ![]() ![]() ![]() |
Hi Dan
Where are you from? Do you know what make the kit is or was? Are you wanting to refit? Current stable:
http://www.lpgtrade.com/software/king/KING...iagram.pdf
Strange, mine just stalls if the maf is not connected and will not run at all.... |
Ding what engine have you got?
4.2 Sc, disconnect the maf and it stalls and will not start again until the maf is reconnected, I'm not at home at the moment but will give it a go once I get back to double check |
very odd...
I’m pretty sure mine with gas setup (although not currently used) does with no maf as I tried it while trouble shooting last year.
HELLO ALL!!!!!!
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
well done |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Nice one. That must have been so satisfying to hear it come alive. |
Nice one - are you going to get a tank for the gas or even if you don’t use it or attempt to unravel the spaghetti for loom Current stable:
