![]() | Home > Technical (L322) > MY12 TDV8 4.4 restricted performance. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
http://www.fullfatrr.com/forum/topic43541-75.html G reg 2.5VM Vogue Portofino red 1991- 1999
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Thanks Stan & BB
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
Just referring to the cost of components, when one of my inlet hoses split giving my restricted performance, it cost just over £100 for the four rubbers and new jubilee clips... |
MattC Member Since: 27 Oct 2016 Location: Surrey Posts: 25 ![]() ![]() ![]() |
Has anyone got a link to Samco/similar hoses for the air intake manifold for the 4.4 tdv8 (2011)? |
I know this thread is 3 yrs old but a replacement inlet manifold (one side only) has been quoted at a LR specialist (non LR Main dealer) at£1600 all in. 😳😱😢
mattgage Member Since: 21 Apr 2014 Location: Suffolk Posts: 38 ![]() ![]() ![]() |
Quick and clean result. Can I ask the experts if there is anywhere on these inlet hoses that is more likely to split? I'm about to do the oil cooler and back O rings so will have a good look at the manifold etc while cleaning it all up. Thanks. |
They tend to split around the edges of the clips.
Thanks Mike - and for additional vital info on the 4.4 TDV8 oil weeps! |
Not going to start a new thread as this one is still likely to be relevant.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1268 ![]() ![]() ![]() |
Can some clever soul put an arrow on this picture as to where the manifold usually splits please? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4319 ![]() ![]() ![]() |
Dolphin - looks like you still have the 4 |
Kevinp
@dr rob - had a hi pressure smoke test and they are fine apparently but yes I will get them changed at some point
@kevinp
