Home > Technical (L322) > MY12 TDV8 4.4 restricted performance.
Page 2 of 3 <123>
GGDR
Ah thanks Stan! Thumbs Up
Is it called something else? I remember a thread on it...
. Cheers, Greg
Post #449230 27th Aug 2017 8:25am
Baltic Blue
http://www.fullfatrr.com/forum/topic43541-75.html G reg 2.5VM Vogue Portofino red 1991- 1999
Post #449231 27th Aug 2017 8:34am
GGDR
Thanks Stan & BB
. Cheers, Greg
Post #449315 28th Aug 2017 12:27pm
stu
Just referring to the cost of components, when one of my inlet hoses split giving my restricted performance, it cost just over £100 for the four rubbers and new jubilee clips... Shocked
So £400 for the whole sheebang and labour is very good!
Just for the future, if any of the intake pipes split again I will not be visiting L/R as it is just normal automotive hose which you would find on any intake or intercooler. If you wanted to splash the cash a bit even some good quality silicon hose like Samco for example would still be cheaper. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #449337 28th Aug 2017 3:04pm
MattC
United Kingdom 2011 Range Rover Vogue SE TDV8 Alaska White
Has anyone got a link to Samco/similar hoses for the air intake manifold for the 4.4 tdv8 (2011)?
Post #458785 28th Nov 2017 9:33am
Dolphinboy
I know this thread is 3 yrs old but a replacement inlet manifold (one side only) has been quoted at a LR specialist (non LR Main dealer) at£1600 all in. 😳😱😢
The injector leads (or something around there) have to be replaced as they are one use only.
Post #543366 7th Feb 2020 9:44pm
mattgage
United Kingdom 2011 Range Rover Vogue TDV8 Orkney Grey
Quick and clean result. Can I ask the experts if there is anywhere on these inlet hoses that is more likely to split? I'm about to do the oil cooler and back O rings so will have a good look at the manifold etc while cleaning it all up. Thanks.
Post #543395 8th Feb 2020 9:03am
Baltic Blue
They tend to split around the edges of the clips.
A gentle wipe over with a clean white tissue or kitchen roll will usually show tell tale signs of leaking soot oil residue.
Post #543396 8th Feb 2020 9:28am
mattgage
Thanks Mike - and for additional vital info on the 4.4 TDV8 oil weeps!
Post #543398 8th Feb 2020 9:34am
Dolphinboy
Not going to start a new thread as this one is still likely to be relevant.
Car had dpf clean a few weeks ago and has been driving 100%, regenning fine etc. Was on motorway and suddenly went into restricted performance (RP) and even clearing with IID tool kept popping back into RP. No faults came up, just red RP sign. Interestingly on normal roads it is mostly fine, even when revving up to 2500 revs, although it went into RP occasionally.
Have looked at the engine. There is some black liquid on the inlet manifold and the black pipes on the right hand (pax) side if the engine. Can anyone identify what they are please? And the silver small cooler on the far right? Car is booked into LR on Monday but I seem to have as good knowledge as them at the moment Shocked
Post #545667 1st Mar 2020 2:08pm
kevinp
Mcfly309 wrote:
Back on my drive by early Tuesday afternoon.
I can't thank Maltings Off Road enough!!! It was my first experience with them and they really couldn't have done more to keep me happy. Chuffed to bits.
Bow down
Can some clever soul put an arrow on this picture as to where the manifold usually splits please?
Post #545715 1st Mar 2020 7:56pm
DrRob
Dolphin - looks like you still have the 4 Censored original inlet hoses on your motor. Swap them out for new upgraded silicone hoses. Lots of info on here how to Thumbs Up
They should look like the ones in GGDR photo and this
 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #545717 1st Mar 2020 8:24pm
Baltic Blue
Kevinp
Whenever people have talked about splits in the plenum it has always been the welded seam that has failed.
Presumably that could be anywhere around the joint.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #545719 1st Mar 2020 8:43pm
Dolphinboy
@dr rob - had a hi pressure smoke test and they are fine apparently but yes I will get them changed at some point
@kevinp.
As I understand it, they tend to crack around the red area (ignore the green arrow). There is plenty on the jag and disco tdv6 forums about cracking (the manifold Is plastic apparently)! Shocked
Post #545726 1st Mar 2020 9:48pm
Dolphinboy
@kevinp
The seam that is most likely is here (green arrow) although mine is apparently between and under the two pipes (red arrow)
Post #545728 1st Mar 2020 9:56pm
Page 2 of 3 <123>
