Home > In Car Electronics (L322) > upgrade to DAB+ |
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 146 |
Can you tell me which ones of the four pins are the Batt and earthpin on the Module? Don't like to do the "try and error" way. |
18th Jan 2020 1:40pm |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 335 |
Ansi
18th Jan 2020 3:26pm |
Thanks for your reply, will give'm a try tomorrow. It sucks without DAB+. |
18th Jan 2020 4:19pm |
19th Jan 2020 1:03pm |
In very short term: ain’t no good!
23rd Jan 2020 7:46pm |
the_ferret82 Member Since: 10 Jan 2020 Location: Hertfordshire Posts: 50 |
I recently did this module upgrade in my Jag XF. (same electronics). went from a 2 pin connector to a 4 ping and after working out JLR had swapped the pins around i got the module installed and working with ease.
27th Jan 2020 2:06pm |
You mean the one pin on the left towards the corner is the earth and the very next one ist the power or did I get this wrong?
27th Jan 2020 8:31pm |
yes the pin on the left near the corner is the ground and the pin far right is the power. the other pins are not used.
28th Jan 2020 2:33pm |
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 |
I bought a DAB tuner with antenna and FM Tx and Bluetooth from Wish for £28 it plugs in cigar and is portable not a bad solution. |
28th Jan 2020 2:42pm |
Just gave'm an other try, no luck at all. I can "push" the DAB button but no reaction, if I push the button with the original DAB installed it would work only we do not have dab in CH only DAB+. Need the D-JV-2 module to get happy again. |
1st Feb 2020 11:36am |
WdeRave Member Since: 25 Apr 2019 Location: Javea, Alicante Posts: 17 |
Hi Guys, I bought a DAB+ module, including bracket and custom connector converters via OLDJaguar. Not cheap, but came with a clear manual, easy to install and works flawless using the standard interface
3rd Mar 2020 7:26pm |
Looks good and the perfect solution.
3rd Mar 2020 8:37pm |
Mail form Feb 2019:
3rd Mar 2020 8:47pm |
WdeRave
3rd Mar 2020 8:56pm |
