![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
I tackled this job today having sourced the correct O rings. A massive thank you to all who contributed to this as it made the job a lot easier to tackle, in fact the hardest part for me was trying to find the right tools buried deep in my shed. |
I notice that a few people in this post have used blue hylomar when replacing the seals in the oil cooler. I take it that it’s a thin bead either side of where the gasket sits.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
I fitted each gasket to its housing then coated the protruding gasket with sealant. |
Thanks Graeme, I’ll give that a go, don’t fancy having to pull it all apart again once it’s done |
Got around to sorting the gaskets on my oil cooler this weekend was paranoid about breaking the coolant hose at the front that seems to be a known brittle item so took my time. Found the right rear plenum hose ( one of the four) hadn’t been fitted properly, looked fine from above but hadn’t seated correctly underneath, needless to say the right hand bank as you look at the engine was covered in sticky black crud. Managed to get the oil cooler out with no real problems and it’s just as well as it was obviously leaking. The old gaskets were hard and flat whereas the new ones were pliable and sat slightly proud once installed. As advised on here I also applied some hylomar and refitted making sure that all bolts were torqued to the correct nm. I also cleaned the throttle body and MAF which were both filthy. I contemplated cleaning out the plenum too but the crud was thick and sticky so not really practical on the driveway. Car is running fine with no noticeable difference so it’s a case of checking for any further leaks next week to make sure all is ok. |
madpugger Member Since: 07 Feb 2013 Location: Aberdeenshire Posts: 49 ![]() ![]() |
How hard is it to change the other end (at the Turbos)? |
AlanS Member Since: 23 May 2019 Location: North Lincolnshire Posts: 18 ![]() ![]() ![]() |
Just for the record. I have just replaced my O rings with the above size. Checked for leaks before I put the air inlet thingy back on and it was dripping straight away. I've ordered some Vitron 9.00ID X 2.0c/s and see if they are a better fit. 2012 L322 4.4 TDV8 2001 P38 2.5 BMW |
No need to disturb the other ends of the pipe unless wanting to replace the pipe. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
I have a leak in that area (secondary turbo / passenger side UK) and thinking it could well be the o-ring at the turbo end.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
i have some 'o' rings Greg, you're welcome to them if you need them.. ... - .- -.
thanks Stan, i have a couple left from when I did the upper one so will ok but very kind of you to offer, thank you.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Greg,
Thanks Mike, although my secondary turbo isn’t called on that often, manifold temps alone make me wonder about that o-ring the more I think about it. Just think about DPF regeneration temps and bear in mind I am doing that quite regularly.
plumajp Member Since: 18 Jul 2013 Location: bridgend south wales Posts: 73 ![]() ![]() ![]() |
So wheres best to buy the best size/material o rings for an l405? Uk
