Home > In Car Electronics (L322) > upgrade to DAB+
Page 4 of 8 <12345678>
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Patrick
No I didn’t.
The first problem was the power connector. The DAB+ unit has a four pin connector. I used a meter to find the Batt and Earth connections and rigged up power. All other connections are the same.
DAB still appears on the screen muni, but I couldn’t select it and therefore couldn’t "see" the u it it tune it. I tried it with a second unit of exactly the same software level as the OP, still no luck.
I’m now looking at a Dension DBU3GEN, which plugs into the USB socket.
Post #533462 7th Nov 2019 9:02pm
Alinton
Ireland 2011 Range Rover Vogue TDV8 Zambezi Silver
I wonder if swapping out a DAB module for this DAB+ module will work.
I might try it. Could easily sell the module again if it doesn't work.
Post #533489 8th Nov 2019 9:37am
jz
Does swapping out for orig DAB unit for CPLA-14F720-BM (DBAB+ per this thread) actually work in a 2011 L322?
Post #533503 8th Nov 2019 11:02am
millerj90
It didn't work for me (2012 Westminster).
It appeared on the menu, but I couldn't select it.
YMMV
Post #533504 8th Nov 2019 11:13am
jz
thanks - anyone have a scooby of how this chap got it done then??
Re: upgrade to DAB+ Report post
chief64 wrote:
Upgrade done, install new DAB+ unit CPLA-14F720-BM, working good.
Post #533505 8th Nov 2019 11:19am
Alinton
Where exactly is the DAB module?
Post #534690 18th Nov 2019 2:03pm
near side rear cubby, location pics are on page one.. ... - .- -.
Post #534693 18th Nov 2019 2:39pm
Alinton
Thats just a picture of the cubby. Where in there is the module?
Post #534816 19th Nov 2019 4:24pm
Markwood71
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
Does anyone know if there is a DAB+ adapter that might cast to the bluetooth?
Post #535500 26th Nov 2019 10:53am
i'm pretty sure all the after market jobbys cast to a FM frequency .. ... - .- -.
Post #535506 26th Nov 2019 12:20pm
ikjos
Norway 2012 Range Rover Westminster 4.4 V8 Santorini Black
What about this one:
In2Digi D-JV-2
https://www.in2digi.com/products/
https://www.in2digi.com/downloads/D-JV-2/D-JV-2-key-points.pdf
Apparently fully integrates with the infotainment. Must be enabled via IIDtool or eqv.
Post #535516 26th Nov 2019 2:17pm
Markwood71
This infers that its " Plug & Play " ?
• DAB to DAB+ Update :
 Simply exchange the OEM part for the in2digi module
(requires basic modifications to power and antenna connections)
 No new vehicle DAB install configuration required
* Edited-
Plug & play for 2010 onwards Welcome Rosie J - The Newer Kid on the Block
RIP Rosie (We all Love Rosie - especially in S mode at the traffic lights)
Post #535523 26th Nov 2019 2:58pm
Alinton
Nice find!
Pricey, but if it works and adds DAB and DAB+, maybe it's worth it?
Trouble is I'd need two, one for the RR and one for the Jag XF!
Post #535532 26th Nov 2019 4:44pm
Alinton
Tell y'all what - I have two factory DAB modules in my cars. As I'm a broadcast engineer I really want DAB+.
If you don't care about the +, but want DAB, I'll sell you my factory modules for 250 - half the price of the In2Digi module.
Then we subsidise each other!
A
Post #535610 27th Nov 2019 11:16am
Alinton
Didn't work for me either. I tried selecting the various different DAB options in the CCF, same result.
YMMV
Post #535714 28th Nov 2019 9:03am
