![]() | Home > Maintenance & Mods (L322) > 4.4TDV8 - Oil leak from front / low / right side of engine |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4320 ![]() ![]() ![]() |
Greg - I presume you are still searching for an answer to your oil drip source? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I’ll have some news for you all soon on oil leaks |
So, looks like secondary turbo (nearside) is leaking which is dripping on front diff AND oil pump "plugs" which is leaking onto front face of sump area. Had it diagnosed at two separate independent specialists over last two weeks. All fixable but your reserve pot better be healthy |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
I did wonder about that turbo. It's just so hard to get to so I've not been able to see a source.
I'm not 100% if it has or not. I don't think so but going to have it confirmed. I boot it regularly and never had a smoke screen. Indy who is fixing does not carry out turbo drain mod. They are not prepared to drill into a block |
If you have any pictures of that zone I can tell you.
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
Can I join the party |
I’m using Rovertune. Give Rob there a call and get his lads to look at it. He’ll drop you at the station too |
Front leak was from the oil pump and rear leak was from the secondary turbo.
I boot it regularly and I’m 100% sure drain mod not done. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
John, I bet an old tyre that your front leak will be an oil pump plug like mine and Ninos. It’s a tricky thing to get to but Rovertune did mine same time as the turbo. They see a few of these leaks so Phil the mechanic knows his way around it. I also took the opportunity to have all the front belt idlers done and new belts fitted to cure my cold start squeak ![]() They are just about to open a customers “office” upstairs with free WiFi, TV, desks, coffee etc. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Thanks Rob, I think it will be that too.
I use Gunk in a spray can these days. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
