Home > Maintenance & Mods (L322) > 4.4TDV8 - Oil leak from front / low / right side of engine |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Hi Graeme, thanks for the info. Good to know it's a gasket vs o-ring.
4th Jul 2018 6:14am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
greg, the drain mod tsb shows your pic you posted previous on page 7 and the modified drain on page 14..hope this helps .
4th Jul 2018 7:33am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2470 |
I spotted today that mine has caught the oil leak bug with oil all over the back of the engine. The source appears to be the oil filter/cooler housing gasket. Not really any oil forward of the housing but plenty just over the back. |
4th Jul 2018 7:57am |
have you had the mod done Graeme? ... - .- -.
4th Jul 2018 7:58am |
Yes, it was done by the LR dealer at my request as a condition of the purchase. Having only travelled 18K kms the turbo was still tight so no evidence of the problem but I knew that it would become a problem sooner or later. |
4th Jul 2018 8:14am |
so whats the fix for this then.. ... - .- -.
4th Jul 2018 8:21am |
The fix for my oil leak?
4th Jul 2018 8:23am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
Good luck Greg,
4th Jul 2018 8:38am |
like mike says, hope you find the leak. ... - .- -.
4th Jul 2018 8:51am |
Cheers chaps. This one's been a bit sidelined by my full DPF which has taken priority!
6th Jul 2018 6:51am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Greg
17th May 2019 10:03am |
Hi Rob, no haven't found it.
17th May 2019 11:53am |
Did you take the sump cover off to get a better look see? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
17th May 2019 12:04pm |
yes, had both sump covers off.
17th May 2019 12:08pm |
