![]() | Home > Technical (L322) > Splutter, jerk, judder restricted performance mystery SOLVED |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Found it:
. Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Bit of an update guys, yesterday I got an additional code:
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Greg,
Thanks Mike, yes I did study that.
Partial update, might be onto something:
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Glad you seem to be getting to the problem Greg , however if anyone ever need a petrol engine its you sir. How do you sleep at night worrying about your soot levels |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 751 ![]() ![]() |
proof if it were needed of the North/South divide - this is my smoke tester, us impoverished Northerners can't afford to buy luxuries like a smoke leak detector.
Except you've got a fancy compressor hooked up to your tin cass. !
Ok I did further smoke tests, CSOV and pretty confident it was the loose intercooler to throttle body pipe as mentioned earlier.
And this one is: SOLVED.
Alinton Member Since: 05 Aug 2019 Location: Kilkenny Posts: 56 ![]() ![]() ![]() |
Old thread I know, but it's helped me! Same symptoms, I opened the bonnet with dread this morning.
nice one Alinton
