Home > Technical (L322) > Splutter, jerk, judder restricted performance mystery SOLVED
Page 3 of 5 <12345>
nino_nino
Greg, pm sent. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #527877 13th Sep 2019 10:07am
Baltic Blue
Just found this picture in my collection.
Post #527944 13th Sep 2019 7:13pm
GGDR
Thx Nino.
And Mike.
Recognise those pix Mike from a good post on CSOV: https://www.fullfatrr.com/forum/topic49556.html?highlight=csov
..which I've been studying ready to get my head in the engine bay tomorrow again, WD40 at the ready.
Some of your pix there too Nino Thumbs Up
. Cheers, Greg
Post #527956 13th Sep 2019 9:42pm
nino_nino
Greg, if you have vacuum pump /hand brake bleeder pump/ you can check if the valve is working ok. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #527975 14th Sep 2019 9:53am
Baltic Blue
Rolling with laughter bit of a sore point Nino, Greg and vacuum pumps, but I would suggest, if it is old design with nut on top, just remove nut, or at least undo it to the top of the thread so that you can try levering it up a bit to work in plenty of WD 40.
Post #527976 14th Sep 2019 10:08am
nino_nino
Rolling with laughter the very thought did occur to me to.
Greg you can try and push lever in a bit to see if it moves. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #527978 14th Sep 2019 10:38am
GGDR
Ok front undertray off (geez a lot of bolts on that front one, only three for the middle one for oil changes)
Got a bolt on my CSOV, sprayed it - and tried to feel for lateral movement on the rod, I.e rod back and forth like a piston,
Is that correct?
. Cheers, Greg
Post #527984 14th Sep 2019 2:10pm
nino_nino
that is correct Greg, it is stiff, that is normal. Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #527987 14th Sep 2019 2:29pm
Baltic Blue
Just got home Greg, how did it go?
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #528007 14th Sep 2019 7:51pm
GGDR
ok so been under again, Nino as you say it's very stiff.
But I can pull it a fair way and it snaps back.
Still investigating....
. Cheers, Greg
Post #528008 14th Sep 2019 7:55pm
GGDR
Just reading the manual, is it me or do they call that same valve different things:
Manual, Diagnostic Trouble Codes:
- Turbine Intake Solenoid Valve TSOV
- Boost air solenoid CSOV
Manual, Engine Turbocharger:
- Charge Air Inlet Valve
TSB
- Compressor Shut Off Valve CSOV
Is it all the same valve? I think so. Cheers, Greg
Post #528010 14th Sep 2019 8:03pm
Baltic Blue
I have definitely misunderstood what the valve does.
I was always under the belief that it opened when the engine calls for the 2nd turbo, ie about 2500 RPM.
Failure to open gives restricted performance alarm then ??
If you believe it is moving correctly, then you can only clear the fault code and see if it reappears .
Post #528012 14th Sep 2019 8:40pm
GGDR
It's a maze of plumbing alright:
1 Air filter RH
2 Manifold Absolute Pressure and Temperature (MAPT) sensor (2 off)
3 Air filter LH
4 Charge air cooler
5 Throttle
6 Compressor shut-off valve
7 Recirculation valve
8 Engine
9 Variable vane turbocharger
10 Catalytic Converter
11 Diesel Particulate Filter (DPF)
12 Turbine shut-off valve
13 Fixed vane turbine
Fresh air is drawn through the air filter and the MAF (mass air flow) meter to the primary turbocharger compressor. The compressed air is then passed through the charge air cooler and into the engine.
The turbine shut-off valve on the secondary turbocharger is closed and therefore exhaust gasses are unable to operate the secondary turbocharger turbine. In this condition all turbo charging boost pressure is produced by the primary turbocharger using exhaust gasses from all 8 cylinders, giving exceptional response.
(blue text from workshop manual)
Trying to get my head around this valve myself.
Especially trying to understand the difference/significance of 6 and 7
Why two names? Weird
Nino you had yours off was that just to clean it because you clean everything?
(wish I had time for that!)
. Cheers, Greg
Post #528015 14th Sep 2019 9:01pm
GGDR
Ok makes a bit more sense now that I'd been staring at it for bit....
Mike your original description is correct according to this:
The Primary turbo blows straight into the intercooler. SO it's weird I am having problems at very low speed. Assuming the error code and workshop manual direction is correct.
Ok back to the code actions form the WM:
P1247-00 =
Turbocharger Boost Pressure Low - No sub type information =
Turbocharger actuator jammed =
a) If this DTC is logged with P00BC-00, suspect compressor recirculation valve (CRV) stuck open. If this DTC is logged with P00BE-00, suspect boost air solenoid (CSOV) stuck closed
b) Check Turbocharger actuator jammed. Check and install Turbocharger actuator. Refer to the Warranty Policy and Procedures manual, or determine if any prior approval programme is in operation, prior to the installation of a new module/component
No I don't have P1247-00 +P00BC-00 or P00BE-00
I just have P1247-00.
So must be Turbocharger actuator. Wondering which turbo. Probably primary, although it doesn't say.
Now I need to find find this Turbocharger actuator....
. Cheers, Greg
Post #528019 14th Sep 2019 10:14pm
GGDR
A quick search for the actuator:
God I don't know how I'm gong to get to that... Shocked Cheers, Greg
Post #528021 14th Sep 2019 10:27pm
Page 3 of 5 <12345>
