Home > Maintenance & Mods (L322) > Oil removal 4.4L TDV8
Page 8 of 13 <123 ... 789 ... 111213>
DrRob
ffaffage wrote:
On the black tube at the back that runs top to bottom, there are two small horizontal holes in the plastic cube at the top - one points in towards the oil reservoir, one points outwards. The air pumps out of those, covering them with a couple of fingers makes it impossible to push the pump handle downards.
Mine is brand new, never used and I concur it does the same with fingers over both holes Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #526102 25th Aug 2019 5:30pm
GGDR
The hole in the pic within the silver block DrRob?
. Cheers, Greg
Post #526103 25th Aug 2019 5:37pm
ffaffage
The ones in the silver nut I would say - that's plastic on mine. In this photo, I've shoved a carb cleaning brush into the hole.
Post #526104 25th Aug 2019 5:48pm
GGDR
many thanks.
this confirms mine's a duff.
Thanks for all the help guys.
. Cheers, Greg
Post #526106 25th Aug 2019 6:16pm
DrRob
Happy to help Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #526108 25th Aug 2019 7:10pm
DrRob
Oil and torque wrench on its way. I’m one step closer to joining the home oil change club Thumbs Up Rolling with laughter Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #526253 27th Aug 2019 3:42pm
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
GGDR wrote:
Any reason 3k oil changes? Seems pretty frequent
Hi
First off, a great forum! Ordered the draper vacuum pump yesterday! Didn't think my 2012 V8 DIESEL had a pipe I could use but after a second look having rear your posting it was discovered near the filler tube.
Thanks for your help all.
Dave
Post #527686 11th Sep 2019 1:04pm
Baltic Blue
Mine also work out to about 3k miles because I have been doing it every 6 months and I only did 6k miles last year.
It keeps me young being active OAP Rolling with laughter
Mike.
These 2 threads should be linked.
https://www.fullfatrr.com/forum/topic52637.html G reg 2.5VM Vogue Portofino red 1991- 1999
Post #527697 11th Sep 2019 2:41pm
Nylands
Hi Mike
Certainly keeping the old grey cells working for this OAP! Might need some help setting the draper pump up when it comes. I can appreciate the idea of pulling the oil out by suction with the hand lever but wonder about the compressor element use. The method of syphoning also comes to mind but that depends on levels being right.
Either way a look underneath at the weekend was not what I was expecting, so keen do do it using the pump. DIY means getting the right oil and filter etc.
Regards
Dave
Post #527770 12th Sep 2019 8:06am
Baltic Blue
Dave,
https://www.fullfatrr.com/forum/topic52688.html
I was asked for this guide by another “sucker”.
Just shout if you need any more help.
Post #527774 12th Sep 2019 8:14am
Nylands
Thanks Mike!
Cool
Post #527780 12th Sep 2019 8:27am
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
Hi there, this post has been really useful and educational so thanks :¬) I've got a question, how the hell does the "non exiastant" dipstick come out ? I've truned mine anti clock and it pulls up an inch then its solid, how did you remove yours ??
Karl
Post #530091 5th Oct 2019 12:04pm
Baltic Blue
Rolling with laughter Try two weetabix for breakfast.
It’s like a bayonet light bulb fitting , 1/4 turn then it just pulls off with a good tug.
Post #530092 5th Oct 2019 12:56pm
Nylands
Karl
It had me fooled also with pulling rather than unwinding.
David
Post #530177 6th Oct 2019 2:13pm
Nylands
Baltic Blue wrote:
Cheers Nino,
I will recheck the level tomorrow.
I put 8.5 litre in.
At 8 litre it was showing half full, but it was cold new oil at that time.
Just lit the bbq to make up for my lost lunch.
Stan,
You would be blown away with the beauty of sunny Saddleworth, 😁😁
Mike.
Post #533147 4th Nov 2019 4:04pm
