Home > Technical (L322) > 2010 Heated/Cooled Seat not working
Page 11 of 27 <123 ... 101112 ... 252627>
GGDR
Still not sorted. There have been mornings this week and last week when the Mustang unit starts, runs for 5 then shuts down. If I turned off the engine, lock the car (say to pop into a shop) and then once back in the car the seat gets very warm.
Other mornings working fine first go.
So still an issue there. Maybe controller not completely happy with parameters of the Mustang unit.
. Cheers, Greg
Post #501361 12th Jan 2019 10:33pm
Eac 11
United Kingdom 2012 Range Rover Westminster TDV8 Fuji White
gonna_go_double_r
Hi, I am also experiencing problems with my heating function on the driver's seat. Cooling works fine but when the fan kicks on to heat it does so for a few seconds then cuts off which sounds like the thermistor. I had noticed in your previous upload that you have brought a new seat cushion when you stripped the seat and want to do the same. I was wondering if you had the part number? Cheers and hope you get your Mustang unit to cooperate.
Post #505291 15th Feb 2019 9:32pm
GGDR
Hi Eac11, sadly I've not succeeded with my experimental fitting of the Ford Mustang unit.
Pls see https://www.fullfatrr.com/forum/post501998.html#501998
. Cheers, Greg
Post #505363 16th Feb 2019 3:37pm
Eac 11
gonna_go_double_r
Thanks for the speedy reply.... Really thought the Mustang unit was going to be a success. Do you have the part numbers for the main base seat cushion, foam ducting and the foam topper?
Cheers.
Post #505616 18th Feb 2019 11:55pm
GGDR
I got this from Dan, but you can check microcat for the actual PN's
. Cheers, Greg
Post #505617 19th Feb 2019 12:27am
iainvr4
2004 Range Rover Vogue Td6 Java Black
How do you get the back of the seat to come off? Are they attached by screws or clips?
Post #506029 22nd Feb 2019 3:30pm
Markbhai
England 2006 Range Rover Vogue Td6 Buckingham Blue
I Have just fixed this on mine, mine was the fan assembly in the back of the seat, the part was around £125 and I got my local garage to change it for me.
Post #506238 24th Feb 2019 8:46pm
Eac 11
I know it's late but thanks for your help gonna_go_double_r
Seats repaired with a genuine replacement rear fan unit as it seemed the thermistor had gone due to overheating and a new base cushion.
Had any luck with getting the Mustang unit to work, just out of curiosity?
Post #521743 14th Jul 2019 11:48pm
Eac 11
What fan unit did you buy if you don't mind me asking for £ 125 as I recalled the genuine part being more like £250. Just for future reference. Thumbs Up
Post #521744 14th Jul 2019 11:48pm
DrRob
Some pointers please....seat base cooling works but not seat back...
Is it likely to be the split ducting issue?
Thanks in advance
Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #524371 10th Aug 2019 1:21pm
GGDR
Yes could be ducting. The units are more likely to fail in heat mode.
Problem is the broken ducting can screw the unit. I tried a duct repair but it was in vain and I had to just plump and replace the unit anyway. But that was a heat fail.
. Cheers, Greg
Post #524374 10th Aug 2019 1:36pm
DrRob
Thanks.
Sticking this here as it might help folks Thumbs Up
https://www.facebook.com/groups/2120243954...979587067/ Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #524375 10th Aug 2019 1:43pm
DrRob
So, it heats both base and back but only cools base... Whistle
Thoughts? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #524643 13th Aug 2019 4:37pm
GGDR
Could be duct, get the back off the seat (bit of a phaff) and inspect the unit to start Rob.
. Cheers, Greg
Post #524646 13th Aug 2019 4:58pm
DrRob
Will do. Looks like seat back can be removed by carefully following the instructions here. As ever, very helpful Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #524708 13th Aug 2019 9:53pm
