Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
Eac 11 Member Since: 15 Feb 2019 Location: Cheshire Posts: 4 |
gonna_go_double_r
15th Feb 2019 8:32pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Hi Eac11, sadly I've not succeeded with my experimental fitting of the Ford Mustang unit.
16th Feb 2019 2:37pm |
gonna_go_double_r
18th Feb 2019 10:55pm |
I got this from Dan, but you can check microcat for the actual PN's
18th Feb 2019 11:27pm |
iainvr4 Member Since: 15 Mar 2013 Location: glasgow Posts: 16 |
How do you get the back of the seat to come off? Are they attached by screws or clips? |
22nd Feb 2019 2:30pm |
Markbhai Member Since: 05 Jul 2015 Location: bradford Posts: 20 |
I Have just fixed this on mine, mine was the fan assembly in the back of the seat, the part was around £125 and I got my local garage to change it for me. |
24th Feb 2019 7:46pm |
I know it's late but thanks for your help gonna_go_double_r
14th Jul 2019 10:48pm |
What fan unit did you buy if you don't mind me asking for £ 125 as I recalled the genuine part being more like £250. Just for future reference. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4298 |
Some pointers please....seat base cooling works but not seat back...
10th Aug 2019 12:21pm |
Yes could be ducting. The units are more likely to fail in heat mode.
10th Aug 2019 12:36pm |
Thanks.
10th Aug 2019 12:43pm |
So, it heats both base and back but only cools base... Thoughts? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
13th Aug 2019 3:37pm |
Could be duct, get the back off the seat (bit of a phaff) and inspect the unit to start Rob.
13th Aug 2019 3:58pm |
Will do. Looks like seat back can be removed by carefully following the instructions here. As ever, very helpful Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
13th Aug 2019 8:53pm |
