Home > Technical (L322) > TDV8 whistle |
Bogi 6357 Member Since: 28 Jul 2019 Location: Scottish Borders Posts: 54 |
I’ve got it half stripped down at minute as I blanked the egr pipes off after dinner this evening with the kit , the manifold does look manky but Still haven’t properly checked it yet , I’ve removed the support bar and various cables so I can give it a good soapy water test In the morning , the only performance related error I seem to have had was when I thought I had popped the turbo but turned out to be dodgey fuel tank sender and I had run out of fuel ,the whistle isn’t there until under load and vehicle is in motion so I think it probably is the exhaust manifold , this site is an absolute god send though 👍 |
3rd Aug 2019 8:47pm |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 |
The inlet manifold doesn't usually crack on the central piece, it's the ricker cover parts down either side. Spray them with soapy water. Cracks seem to be along the top edges so can be seen without removing the metal shields.
3rd Aug 2019 9:34pm |
Thanks That gives me a good place to start in the morning 👍
4th Aug 2019 12:51am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1750 |
Post up a video |
4th Aug 2019 8:43am |
mikey I have a selection just working out how to upload 😂 |
4th Aug 2019 8:11pm |
Here is a few you tube links hopefully they work 😀 |
4th Aug 2019 8:50pm |
Does sound very much like a boost leak, and rushing/escaping air
5th Aug 2019 5:42am |
Thanks Mikey , is there an area I should concentrate on , as I don’t have any restricted performance or smoke issues
5th Aug 2019 7:12am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Mine makes this noise. Does it resemble this?
7th Aug 2019 4:32pm |
Hi Andy
7th Aug 2019 6:22pm |
I’ve replaced the top hoses with silicone ones.
7th Aug 2019 6:29pm |
Nothing came of the smoke test then ? , I think I read on a post here that the exhaust gaskets can do strange things also resonate and chatter at certain times also |
7th Aug 2019 6:44pm |
Yes, I found a hole in the air intake from the airbox to the turbo
7th Aug 2019 6:46pm |
Brilliant So was that definitely the cause of your noise ? Did that cause any other symptoms other than your noise |
7th Aug 2019 7:11pm |
