![]() | Home > Technical (L322) > TDV8 whistle |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Some inlet manifolds have cracked causing a whistle.
Bogi 6357 Member Since: 29 Jul 2019 Location: Scottish Borders Posts: 54 ![]() ![]() |
Thanks for the reply , will check the inlet manifolds , hopefully it is that . |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Failing that, there is an excellent independent in Dundee.....DiscoMikey on most forums and MMP Land Rover on Facebook. Very highly regarded |
Yes very Good advice , DM gave me some good pointers when I had the Disco 3
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 757 ![]() ![]() |
Brilliant thanks ,I’m going to go have a look
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
Thanks for the reply Mikey
RH is much easier than LH
Cheers Mikey I’ve got your number , I will give you a bell about booking in once I’ve convinced myself it’s that 😂
Give me as much notice as you can. We're booking for 10th September as it is |
Ahh well the inevitable happened 😂 one or both of my turbos have popped , symptoms cruising along and devoted to accelerate road was quiet and a big long straight section , lose all power and coasted to a stop no noticeable smoke from rear either
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
Doesnt sound like a turbo issue.
I will get the soapy water check done this weekend , I’ve got some methacrylate structural adhesive requisitioned from work
