Home > Technical (L322) > TDV8 whistle
Page 2 of 3 <123>
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
I had a cracked inlet manifold a while back. It gave me the sooty mess on the bonnet soundproofing and restricted performance errors but no whistle.
I'd be thinking about the exhaust manifold for the whistle.
Post #523694 3rd Aug 2019 8:52pm
Bogi 6357
I’ve got it half stripped down at minute as I blanked the egr pipes off after dinner this evening with the kit , the manifold does look manky but Still haven’t properly checked it yet , I’ve removed the support bar and various cables so I can give it a good soapy water test In the morning , the only performance related error I seem to have had was when I thought I had popped the turbo but turned out to be dodgey fuel tank sender and I had run out of fuel ,the whistle isn’t there until under load and vehicle is in motion so I think it probably is the exhaust manifold , this site is an absolute god send though 👍
Post #523697 3rd Aug 2019 9:47pm
gilesharrison
The inlet manifold doesn't usually crack on the central piece, it's the ricker cover parts down either side. Spray them with soapy water. Cracks seem to be along the top edges so can be seen without removing the metal shields.
Exhaust manifold is not so visible! Think I have a slight exhaust manifold leak. I get a bit of a whistle on real full boost. Has done it for over a year, not getting worse, no associated problems.
Post #523700 3rd Aug 2019 10:34pm
Bogi 6357
Thanks That gives me a good place to start in the morning 👍
Not looking forward to putting everything back together , I shouldn’t have taken the support bar out to do the egr blanking .
Thinking of cutting it in half and making a joining bridge piece with 2 wing nuts 😂
Yeah my whistle I can’t hear on full boost probably still there but covered by wind noise ,I can hear mine noticeably 1st 2nd and 3rd gears and when feathering the throttle .
Post #523702 4th Aug 2019 1:51am
Mikey
Post up a video Thumbs Up
Post #523707 4th Aug 2019 9:43am
Bogi 6357
mikey I have a selection just working out how to upload 😂
Post #523771 4th Aug 2019 9:11pm
Bogi 6357
You tube uploads of the whistle !
Here is a few you tube links hopefully they work 😀
Post #523772 4th Aug 2019 9:50pm
Mikey
Does sound very much like a boost leak, and rushing/escaping air
Time to have it smoke tested
Post #523778 5th Aug 2019 6:42am
Bogi 6357
Thanks Mikey , is there an area I should concentrate on , as I don’t have any restricted performance or smoke issues
Thanks for your help much appreciated .
Post #523779 5th Aug 2019 8:12am
Andy
Mine makes this noise. Does it resemble this?
 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #523994 7th Aug 2019 5:32pm
Bogi 6357
Hi Andy
Yours seems to be hissing , my symptom is a definite whistle , most noticeable in last video of the three I posted.
I’ve checked my top hoses can’t see anything a miss and no smoke or error messages , I’ve ordered a silicone hose kit from Lrparts.net should be here tomorrow , have you checked your top hoses to intercooler seems to be a common area for them to let go .
Mine is back at the garage as I had the joyous experience of no brakes this morning and a broken brake line 😂 I still love
It though
Post #524011 7th Aug 2019 7:22pm
Andy
I’ve replaced the top hoses with silicone ones.
I’m told mine is an exhaust manifold stud broken but I took it for a smoke test and when they had it up on the ramp, they checked and said all the studs they could actually see were intact. It’s usually the rearmost ones that snap due to the manifold warping and breaking the stud 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #524012 7th Aug 2019 7:29pm
Bogi 6357
Nothing came of the smoke test then ? , I think I read on a post here that the exhaust gaskets can do strange things also resonate and chatter at certain times also
Post #524017 7th Aug 2019 7:44pm
Andy
Yes, I found a hole in the air intake from the airbox to the turbo
Post #524018 7th Aug 2019 7:46pm
Bogi 6357
Brilliant So was that definitely the cause of your noise ? Did that cause any other symptoms other than your noise
Post #524026 7th Aug 2019 8:11pm
Page 2 of 3 <123>
