Home > Technical (L322) > Auto Wipers |
You'd have the same mirror if you had the rain sensor - it's just the cover around the base that's different.
28th Feb 2011 6:12am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1696 |
Thanks Steve,
28th Feb 2011 8:27am |
I believe everything else is the same (no guarantees,tho). I don't know how much a sensor is - I'd look at the breakers for a sensor/mirror base cover if it's very expensive new. You'll need to make sure the loom is there or you'll need to add that too (split the base cover and check for a 4(?) pin plug. And you'll need a new mounting pad for the sensor (the purple part that sticks to the screen). If that's not avail at the dealers, I'd check autoglass shops.
28th Feb 2011 8:38am |
Hackweg Member Since: 06 Oct 2010 Location: Medway Posts: 22 |
I also have a 54 plate Vogue, and both the automatic wipers and automatic lights do not appear to work, see thread http://www.fullfatrr.com/forum/topic4473.html?highlight=automatic .
28th Feb 2011 9:02am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35248 |
its possible that a reboot of all the ecu's is required ..try disconnecting the battery for at least an hour or so and see if that helps... ... - .- -.
28th Feb 2011 9:49am |
Right - It appears I don't have this option on my 54 plate Vogue (even though it should have been standard).
3rd Mar 2011 7:11pm |
even if you did get the sensor ashley , would you have the wiring there.. ... - .- -.
3rd Mar 2011 7:22pm |
Well according to Dan it should be standard on a 54 vogue. Ii wonder if a previous had had the wrong screen fitted..??
3rd Mar 2011 9:24pm |
heated rear seats should be standard on a vogue, there are two buttons for this on the back of the center console.
4th Mar 2011 8:35am |
Don't think heated seats came in till Aug 04 according to the link,
4th Mar 2011 3:21pm |
Don't mean to drag up an old thread but...
17th May 2011 4:13pm |
I'll take a pick when i have a minute.
17th May 2011 5:02pm |
Cool - thanks mate - I guess it's root around time to see what I can find. I know there was something like that behind the little mic cover in the console but that may be for .... Well..... the mic I guess!!
17th May 2011 6:09pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi, its the same as the mic plug...have you taken the roof consul down as you can see far better and then you wont damage the roof lining. its held in place by 2 screw's, unclip the lights/switches and remove and you will see the 2 screws behind,when its out you will find what you are looking for V8 facelift Range Rover Autobiography 22" wheels.
17th May 2011 6:44pm |
