Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose
Page 15 of 19 <123 ... 141516 171819>
Mikey
MarianaWestminster wrote:
Visited a friend today with a compressor and we made up a boost pressure tester out of some pvc caps and an airline fitting.
Tested the system up to 20 psi and absolutely no leaks to speak of.
So no leaks with the smoke test and none with a pressure test.
I feel we have been over it all and I have done all I can do short of removing the remap or replacing the n/s turbocharger.
Now on the lookout for a replacement vehicle.
Having the EGR blanks remove and the PCM flashed back to standard would be a much cheaper option...
Post #515850 19th May 2019 4:29pm
MarianaWestminster
I dont think I understand what you feel that will achieve Mikey
One of my EGRs is no good and was the reason for blanking and mapping them out originally.
I then drove the car everyday for 1.5-2 months and no problems.
These symptoms appeared after the boost hose split and was replaced. Not after the egr blanking / remap.
Post #515923 20th May 2019 10:37am
Andy
Do you have silicone hoses fitted? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #515925 20th May 2019 10:43am
MarianaWestminster
Yep BAS silicone upper intercooler hoses fitted Andy.
Post #515933 20th May 2019 11:13am
Andy
I’m looking to buy a pair as I think mine have seen better days and might be struggling with the extra boost from the remap. They aren’t visibly torn or cracked but I think they may be porous or too soft and collapsing every now and again. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #515936 20th May 2019 11:29am
Mikey
From the sounds of it, it's the only thing to be eliminated before putting a new turbo on the car...
Post #515944 20th May 2019 1:28pm
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Is it possible you had a slight boost leak before the re map?
I mentioned before when my hose split I had no codes and didn’t notice any reduction in performance. My son heard a hissing, which I traced to a small split in passenger side air cooler outlet hose.
Maybe you had a small leak prior to the mapping, the big split caused the original fault code and now the new hose is causing issues as the new map was originally allowing for a boost leak.
Scratching the bottom of the barrel, I know 2007 3.6 TDV8
Post #516270 23rd May 2019 5:47am
Andy
What’s the latest on this issue? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #517323 3rd Jun 2019 2:43pm
MarianaWestminster
Well I dont believe it.. and neither will you guys.
I bought a facelift 3.6 autobiography to replace the problematic Westminster.
It's been a little over 6 months with this car, engine fine BUT ive just had it apart to replace a bad auxiliary belt tensioner and now its driving crap, all the same symptoms as my other one Banging Head how is this possible?
Only thing I can think of is I did have to remove those damn boost pipes.
Post #542508 31st Jan 2020 8:12am
cheezels
There’s a Jonah a foot 2007 3.6 TDV8
Post #542512 31st Jan 2020 9:06am
MarianaWestminster
So that little trick of removing the upper intercooler pipes and refitting works on this car too!
So something that's common to both cars:
Both have EGRs blanked (new one is not remapped though)
I removed and refitted the boost pipes on both which seems to have caused the problem on both.
Removing and refitting said pipes returns things to normal for a very short while.
Could the pipes not be sealing onto the intercooler or inlet manifold?
I had the Westminster smoke tested and this never showed any leaks but I don't know what pressure that was at.
Can't believe my luck.. should have gone for a supercharged
Post #542548 31st Jan 2020 4:56pm
Mikey
Have you tried either car WITHOUT the EGR blanks fitted?
Post #542577 31st Jan 2020 9:23pm
Nick591
Is it possible the new car has a split in a hose that may have been caused when you removed them? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #542581 31st Jan 2020 10:00pm
MarianaWestminster
Yes Mikey,
Both cars had no egr blanks when bought and were fine for months with blanks fitted.
I've blanked the EGRs on all diesels I've owned and never had anything but positive results. I understand not everybody believes in blanking but I am happy with it.
Possiblt wasting near £100 on new upper intercooler pipes tomorrow Nick just to test.
I can't be the only 3.6 owner in the world to have experienced this... on 2 cars!
Post #542582 31st Jan 2020 10:06pm
Nick591
On this car are you getting any fault codes? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #542585 31st Jan 2020 10:23pm
