Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
As I thought, no air type noise. Just the grunt of a V8 at full chat.
14th May 2019 5:35pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 684 |
Thanks for checking Grofus.
14th May 2019 6:06pm |
No bother. We wanted sorted as much as you do.
14th May 2019 6:08pm |
Thanks Grofus.
14th May 2019 6:54pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
I know how you feel , i have an old Izuzu npr, it started chucking out white smike over 2k revs , four montths later , 3 visits to Izuzu , 4 visits to indies , changed 1.5k euro worth of parts , no fault codes. 4 months later , back to normal out of the blue !!!! I feel your pain sir. 2015 4.4 AB
14th May 2019 6:56pm |
I have been waiting 6 months for this thing to fix itself Dolph!
14th May 2019 9:03pm |
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 |
I'm following this thread closely, it is very odd indeed (and I don't like an unsolved mystery!)
14th May 2019 9:20pm |
Thanks Tugger, I think the sound you describe at initial startup is the viscous fan running which is normal. It quietens down by the time im turning onto the main road.
14th May 2019 9:27pm |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 |
The smoke test might not show a leak which needs heat and high pressure to reveal itself.
14th May 2019 10:57pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2521 |
Perhaps its time to revisit the port deactivation components and wiring. |
15th May 2019 2:13am |
Were both thinking along the same lines cheezels.
15th May 2019 6:35am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1778 |
A boost leak would cause black smoke |
15th May 2019 5:53pm |
Visited a friend today with a compressor and we made up a boost pressure tester out of some pvc caps and an airline fitting.
19th May 2019 4:03pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Might be different when the hoses are hot.
19th May 2019 4:24pm |
