![]() | Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
As I thought, no air type noise. Just the grunt of a V8 at full chat.
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 696 ![]() ![]() |
Thanks for checking Grofus.
No bother. We wanted sorted as much as you do.
Thanks Grofus.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
I know how you feel , i have an old Izuzu npr, it started chucking out white smike over 2k revs , four montths later , 3 visits to Izuzu , 4 visits to indies , changed 1.5k euro worth of parts , no fault codes. 4 months later , back to normal out of the blue !!!! I feel your pain sir. 2015 4.4 AB
I have been waiting 6 months for this thing to fix itself Dolph! |
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 ![]() ![]() ![]() |
I'm following this thread closely, it is very odd indeed (and I don't like an unsolved mystery!)
Thanks Tugger, I think the sound you describe at initial startup is the viscous fan running which is normal. It quietens down by the time im turning onto the main road.
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
The smoke test might not show a leak which needs heat and high pressure to reveal itself.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Perhaps its time to revisit the port deactivation components and wiring. |
Were both thinking along the same lines cheezels.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1790 ![]() ![]() |
A boost leak would cause black smoke |
Visited a friend today with a compressor and we made up a boost pressure tester out of some pvc caps and an airline fitting.
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Might be different when the hoses are hot.
