Home > Maintenance & Mods (L322) > Drivers Door Handle
Page 5 of 5 <12345
Dolphinboy
Bump
Post #447777 14th Aug 2017 8:47am
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
Thread resurrection alert!
Well my driver's side (DS) door is playing up today. unlocked and opened fine. When I tried to close the door it wouldn't close - Seemed like the latch was stuck in the out position.
Eventually the door closed OK, but would not open again. The handle would pull OK from the outside, but didn't open the door latch. I had to get in the back and open the DS door from the inside.
Currently closed and locked OK, but don't want to mess with it until the daylight tomorrow.
It is currently at or below freezing here. So frozen lock or cable broken - which do you think?
Post #459075 30th Nov 2017 6:48pm
Deltaevo
United Kingdom 2002 Range Rover HSE 4.4 V8 Alveston Red
Re: Bloody Nubbin seized in situ!
[quote="Dolphinboy"]great thread this! Had my external door cable go the other day so searched and found this thread: followed it to a tee and got everything off in 35 mins only to find when trying to put the new cable end into the slot that it won't go! so had to take the door locks off (great powerful Uk youtube vid BTW!) to see why not, only to find the old broken end of the wire is firmly and irrevocably seized in the hole! Have tried drilling it out to no avail.
My cable gave up the ghost a few week ago, and I had the same problem, the nipple was seized in the slot. I gave it a good soaking in WD, then took a very fine screwdriver and kept tapping it into the bottom of the nipple. Eventually I managed to free it enough to get the blade right underneath, a little more jiggling and swearing at it and it came out.
Post #459530 4th Dec 2017 9:17am
Gyre8
Tell you what, these cables have shot up in price: 2010 = £7 - £8 each.
Today the cheapest I could find are £23 and upwards.
How's that for inflation!?
Post #459541 4th Dec 2017 11:55am
TpageIRL
Ireland 2008 Range Rover Vogue TDV8 Java Black
I was thinking exactly the same thing. Absolute ripoff for a cable. Explain to me how you can buy this cable in the US for 6 or 7 dollars and we in Ireland and the UK get charged 30-40 euro?
Post #512463 18th Apr 2019 5:12am
dhallworth
Looks like these cables have kept on going up!
Genuine Land Rover cable is now £53.77! Shocked
They’ve gone up nearly 10x in price since this thread started!
Post #655728 5th Feb 2023 7:59pm
garyRR
I just replaced mine with the part from LR Trade Parts.
Looks exactly the same. Was £15 Inc Next Day Delivery.
Took 30 mins to fit. 2015 Range Rover Autobiography 4.4 SDV8
Post #655772 6th Feb 2023 7:03am
ash27
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Another revival for this thread.
Has anyone had issue with the aftermarket parts for the exterior door cable.
I have the FQZ000041.Z8 part (All Makes) from LR Direct and after trying to tweak the fitment as much as I can it feels like the cable is slightly too long.
I can see with the door card off the latch mechanism moves when you pull the door handle however with the door handle fully out the latch can still move another cm or two meaning if I softly pull the handle it wont open the door. I have to yank it to get it to open.
I was going to take the door handle off to have a look at that but just checking am I missing other adjustments?
Cheers,
Ash 07 4.2 Supercharged
Previous:
2011 Volvo v70 D5 | 2009 Honda S2000 | 2010 Mazda MX5 2L | 2006 Vauxhall Astra VXR | 2002 Hyundai Coupe 2L | 2002 Saxo VTR | 1999 Saxo 1.4 | 1999 Saxo 1.1
Post #699112 30th Aug 2024 11:35am
Snowy90 L322
United Kingdom 2004 Range Rover HSE Td6 Giverny Green
Hi Ash and all,
Resurrection of this thread, I bought a non LR replacement fitted it and the same is happening.
Removed and checked against the original and the new one appears to be 5mm longer doesn’t sound a lot but doesn’t operate the lock?
Did you find a solution sounds like the genuine one is the same ie slightly longer?
Before I buy a genuine one and wait for delivery is there any other adjustment needed?
Thanks
Chris
Post #711419 9th Feb 2025 10:59am
ash27
Sorry didn't find any better answer to this.
I assume OEM will just be a bit shorter and therefore work.
I have got use to opening my drivers door with a more intentional pull than any of the others Laughing
If you do order OEM let me know if it works better. They are quite expensive now for a bit of wire Crying or Very sad 07 4.2 Supercharged
Previous:
Post #711490 10th Feb 2025 10:42am
toby1
I found the adjustment screw some help, but alas my pattern cable is also now at the long end of travel. 2012 Vogue TDV8 in Aintree green over sand
Post #711495 10th Feb 2025 11:27am
Snowy90 L322
Hi
Where is the adjustable screw?
I have ordered a genuine cable at £65!!!!
Will update when fitted.
Thanks
Chris
Post #711516 10th Feb 2025 3:38pm
toby1
I thought I'd taken a snap but no. If you look edge-on at the door lock, you may notice a rubber grommet very close. Remove that, and there is a screw.
I can't remember the head size, but anyway, give that a turn left/right and it makes a difference to the handle pull. 2012 Vogue TDV8 in Aintree green over sand
Post #711523 10th Feb 2025 5:08pm
Snowy90 L322
I’ll take a look fingers crossed 🤞
Post #711527 10th Feb 2025 6:18pm
Snowy90 L322
So found the little screw under the gromet tried adjusting left and right didnt make any differnce for me.
i had agenuine cable on order and it arived today, fitted it and door is back working fine.
Just a note my aftermarket cable was 5mm longer than the original (72.5mm) so worth checking before fitting.
All the best we live to fight another day!
Post #711588 11th Feb 2025 5:49pm
Page 5 of 5 <12345
