![]() | Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Dang!
The portion of video you mentioned shows 0 to 60 in about 9 or 10 seconds.
This is quite interesting
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 696 ![]() ![]() |
Had a read through and went out to test those solenoids with SDD.
Ok boss, let us know how the test drive compares please 2007 3.6 TDV8 |
Ok been and had a drive of the 08 3.6.
Ok, so took the upper boost hoses off tonight after work to double triple check and make sure I hadn't disturbed any connectors etc, also removed the n/s turbo to intercooler hose to check it didn't have any problems.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
You will need more milk so take it for another night-time run to see if it still behaves. |
?t=33 .
I need to see a customer this afternoon Graeme so the RR will get another 60 mile run. Will report back |
Burn some sage and shower in holy water 😂
Reading through this thread, you’ve had this occur before, when you’ve removed the hoses to check all is well.
As predicted... back to driving crap. Sick of the RR now.
If you still have the original non-split hose then you could try refitting it in case that silicone hose is affecting air flow. It doesn't remove the silicone hose on the other side though. |
