![]() | Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Are you just changing/checking the hoses or do you disconnect the battery or something else?
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
I can imagine how infuriating this is. Clearly something is being disturbed. Methodically check the multiplugs for good connections especially around the area of the split hose. Could something stupid like a mist of oil on a connection. A small break in wire. Its strange there are no codes though. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 696 ![]() ![]() |
Cheezels,
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Perhaps remove each of the 3 hoses with a drive test between each successive hose to close-in on the area being disturbed that temporarily solves the issue, starting with the lower turbo hose. |
Leave the plastic engine cover off and see how you go. Maybe it’s squishing summat 2007 3.6 TDV8 |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1789 ![]() ![]() |
I’d be checking this, and looking for any excessive oil dripping out... |
This sounds like the old issue you would get on 200 and 300 TDI Discovery engines. De-lamination of the interior of a hose. At idle you are putting ZERO load on the turbos, there will be no appreciable boost. When driving that all changes and if you have a hose that is being 'sucked' from the inside and restricting airflow you'll get sluggish response. The fact you are getting no codes make me think the issue is further along the induction system - engine codes will be generated if the readings from the MAF and MAP don't correlate. If the issue is further up, the codes won't occur. There are two hoses (at the back of the engine) - very short ones - it is possible that one of these is causing an issue. I haven't tried to take these off so can't vouch for how difficult it may be - but they are easily accessible.
That is helpful DMRR, I have already checked the 2 short hoses at the rear of the manifold for splits by loosening the jubilee clips and rotating the hoses whilst in position. I have also removed and checked the 2 90 degree hoses at the front LR and RH of the manifold.
A delaminating turbo to i/c hose on my TD5 D2 caused copious amounts of black smoke and choked the engine until it was stopped to allow the layer to spring back, never recovering under load. However only slight delamination might not have such a drastic effect. |
Ok, I think we are getting somewhere.. where exactly I do not know!
Next time that you remove that hose, look closely at both ends looking for any signs of oil oozing out from between the layers. However next time you remove that hose you might be fitting a new one. |
Graeme,
Sorry mariana, I’m a little confused.
Has rubber material been blown from the old hose and restricting flow. Throttle body for instance.
