![]() | Home > Maintenance & Mods (L322) > Engine replacement - Range Rover 2011 4.4 TDV8 RESCUED |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
As a man who is described by his wife as ‘breaks into a sweat at the sight of a screwdriver’ ...
Salter121 Member Since: 20 Jun 2018 Location: Berkshire Posts: 128 ![]() ![]() ![]() |
Slow progress; but almost there.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
You should invite us all round for a look-see |
Endgame......
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
Getting there!
Not yet........ |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I bet you learned a couple of things about your FFRR.
mrtidy Member Since: 31 Aug 2015 Location: Stockport Posts: 214 ![]() ![]() ![]() |
How's it going ?, I'm sure I'm not the only one who'd like to know? 2009 Vogue SE Zermatt silver |
99.9% - struggling to get the girl started.... she is turning over, firing, and good compression.... but will not start... So close. |
regretting not putting a brand new starter motor in when the engine was out. she just will not crank. guessing it could be the starter motor...not even a click. |
I think I have been beaten. Other than a few pipes left to install, the engine is pretty much 100% together. Battery voltage is good... she is still in neutral following putting her in emergency park release. The rotary gear selector does not raise... it's recognising the key. press the start button... dials come on... i can hear fuel pumps kicking in.... just no crank.
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 153 ![]() ![]() |
Will it crank in neutral? Or does it need to be in park? |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
May sound silly but do you not have to press the brake pedal on that year ? |
