![]() | Home > Maintenance & Mods (L322) > Engine replacement - Range Rover 2011 4.4 TDV8 RESCUED |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2664 ![]() ![]() |
Subscribe to Topix and download either just the 4.4 engine section or better still, download the lot. |
Salter121 Member Since: 20 Jun 2018 Location: Berkshire Posts: 128 ![]() ![]() ![]() |
Thanks; just subscribed to Topix; very useful. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3826 ![]() ![]() ![]() |
The TSB with all the details of the turbo drain mod is in the WIKI.
You might want to look into the oil feed pipe to the turbo’s.
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 ![]() ![]() ![]() |
Watching with interest 2011 RR Autobiography 4.4 TDV8 |
The new engine is now being fitting with all the ancillary parts from the old engine and having the sump's swapped as this is an engine intended for an L405.
Your braver than me, very interesting project though. 2011 RR Autobiography 4.4 TDV8 |
Few images of the old engine
Is there any benefit to using an engine from the L405? 2011 RR Autobiography 4.4 TDV8 |
They are the same engine to the most part; though the sump is different and all the ancillary set up; but the bare long engine its the identical ford engine baring the sump. |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
You're a brave man! Hope it all works out.
Had all 8 injectors tested today and 7 need replacing / refurbing |
I don’t know if their is anything special about 4.4 tdV8 injectors, but I have had a couple of sets of Td6 injectors refurbished at a Bosch service centre in the past and they were as good as new at a fraction of the cost .
