![]() | Home > Maintenance & Mods (L322) > EGR Delete photos ( update +1300miles) more miles |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
Blanking kit arrived this morning and took less than an hour to fit it.. all went well with the encouragement from this thread and the instruction sent with the kit.
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
The last few warm days have seen my mpg go up to 27/28 for my work run which used to be 25ish and local short runs are now over 20 mpg so still happy |
I havent seen any massive difference... will keep and eye over next few days. you are lucky to get 20mpg.. mine sits at 18.5 mpg.. lol Current:
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2942 ![]() ![]() ![]() |
I’m reading so many posts on EGR delete on this and other forums and the positives and negatives provide for some very confusing reading!
Ive not seen any improvement on mpg to be honest.. Im just happy that my oil will be soot free and engine will run cleaner over the time.
I guess it’s worth doing on oil change at the same time then? |
It would take a couple of oil changes to see the difference to be honest. You will start to see the difference. Current:
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 371 ![]() ![]() ![]() |
If people are worried about blanking EGR and an MOT tester seeing it could you not just "sandwich" the blanking plate at the one end of the pipe eith the pipe still in position so it appears normal. I have done this in the past on non LR vehicles. This way even if an MOT tester was trying to have a sneaky look under the engine cover it would be almost impossible to spot 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Another update I've now done over 1300 miles and still no problems
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Just had my EGR blank kit arrive so will fit it this afternoon.
My kit has arrived. Looks a mare of a job on the TDV8 engine.
Just follow the instructions no rush and be careful not to drop anything down the holes
What faults did you have before? |
A couple of injector inm balance faults a and egr faults and the odd restricted performance message
