Home > Maintenance & Mods (L322) > EGR Delete photos ( update +1300miles) more miles |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 518 |
It's not as bad as it looks but be very careful not to drop anything as Henda says. There's a good thread here. I posted a few tips on there.
10th Mar 2019 10:27am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I did mine at the weekend. Little bit fiddly with the support bar bolts but only took an hour. The bolts in the bottom are captive so you can’t drop them.
29th Mar 2019 12:28pm |
Im not sure if it’s in my head but mine seems more rattly now under load. It’s nice and quiet on the move but moving off the traffic lights it sounds like an old Diesel engine.
29th Mar 2019 8:38pm |
Lester Burnham Member Since: 12 Sep 2018 Location: North Posts: 116 |
I did mine (2009 3.6 facelift) whilst its been sitting idle with gearbox problems.
1st Apr 2019 11:21am |
If you have the IID bt tool you can downsload a digital delete onto it from the BAS site for £200 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
1st Apr 2019 11:45am |
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 138 |
Did mine today. Yes a very straightforward job. Time will tell what the difference will be, but she seems a little more responsive. |
2nd Apr 2019 6:25pm |
Can blanking the EGR put pressure anywhere else? Since fitting the blank kit I noticed a slight oil drip last week which was not there before. It has got markedly worse today, enough to fill the undertray, despite minimal use of about 30 miles.
8th Apr 2019 9:19am |
Sounds like pure coincidence. Did you disturb anything when you blanked it off? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
8th Apr 2019 9:25am |
No it was all just wiring up top.
8th Apr 2019 9:39am |
WB Member Since: 26 May 2016 Location: London Posts: 303 |
Thanks Henda for the great guide.
11th Apr 2019 5:00pm |
That’s the kit I bought. They’re very helpful as well. They own range rovers so they know their stuff 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
11th Apr 2019 5:37pm |
That's right, two completely separate jobs. As you saw the EGR replacement is quite involved, whereas the blanking kit is extremely straightforward as all you're removing is two small pipes that are easy to get to, fitting in their place some blanking plugs. |
11th Apr 2019 6:14pm |
Great, thanks telly-addict and thanks Andy, I’ve previously only replaced the two top inter cooler hoses so just wanted to make sure I wasn’t being over ambitious.
11th Apr 2019 6:49pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Deleted |
12th Apr 2019 6:04am |
