![]() | Home > Maintenance & Mods (L322) > EGR Delete photos ( update +1300miles) more miles |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 707 ![]() ![]() ![]() |
The good one needs to stay electrically connected to keep the fault codes away, but not necessarily located where Land Rover intended - lol. Paul, 2001 Discovery 2 TD5, 211,000 miles & climbing 2006 FFRR TDV8 Vogue 151,000 miles & now sold Member of Midland (Land) Rover Owners Club, www.mroc.co.uk |
Henrik07 Member Since: 14 Apr 2016 Location: Bergen Posts: 66 ![]() ![]() ![]() |
Turns out I didn't have dpf's after all. I bought the egr delete map from Bell and installed it. Car runs as sweet as a nut, no faults and flew through its mot two weeks ago. Happy days |
RJDS Member Since: 17 Dec 2016 Location: North Wales Posts: 49 ![]() ![]() ![]() |
If the EGR’s are mapped out, would a faulty EGR cause an error message? 2011 TDV8 4.4 AB Bournville Brown |
If they were mapped out properly, they shouldn't be trying to operate OR generate fault codes / error messages. Paul,
Thanks Paul, guessed as much, but didn’t like to assume that this was the case. 2011 TDV8 4.4 AB Bournville Brown |
If you have a faulty EGR, it's possible to connect the output signal wire to the good one as they operate in tandem. It's pin 2 on both valves, make sure you disconnect the bad one!. I did mine in the E-box, pins H3 & G3 on connector C2518E (connector 'C'), again, disconnect the bad one and link the good one across both sensor inputs.
