Home > Maintenance & Mods (L322) > 2010 - > deployable steps fitting. |
mirras Member Since: 25 Mar 2018 Location: Prestwick Posts: 14 |
I tried all sorts of combinations of button, door and ignition and it makes no difference at all. The LED doesn't flash the two or three times it describes in the booklet either. I'll just live without it. |
9th Apr 2018 6:39am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1188 |
Same here? |
9th Apr 2018 7:59am |
Bear with me.... I have only had my RR for a couple of weeks after moving from a Mercedes S-Class. On the Merc I had access to full dealer level diags and (free) online access to official workshop EPC and maintenance manuals tailored to my VIN. On trying to find the equivalent for the RR I have been looking at IIDTool specs and have come across this setting
10th Apr 2018 6:56am |
Hi, Dolph34
10th Apr 2018 7:47am |
Thank you, I tried the switch exactly as you have listed and bingo, works a treat. I think the 'within 5 seconds' bit is what I missed. |
10th Apr 2018 5:53pm |
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 |
Ah - perfect - glad they are working ok
10th Apr 2018 6:42pm |
Always worth a try thanks, at least it didn't break anything |
10th Apr 2018 6:47pm |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
Great thread guys,
22nd Feb 2019 4:46pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 732 |
I can’t remember if I had to remove the glove box, I think it dropped down enough to give the access needed but I do recall that the wiring for the overhead switch is only just long enough and needs careful routing. I suggest that you reassemble that bit first and take care with the airbag warning light in the overhead panel as it is pretty fragile. |
22nd Feb 2019 9:50pm |
Thanks for the reply cass.
22nd Feb 2019 10:09pm |
You’ll spot the light if you watch the overhead panel when you start it up.
23rd Feb 2019 1:17am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Yes glovebox has to come out.
23rd Feb 2019 6:39am |
Oh yeah I see what you mean lol. What would cause the airbag light on dash then? Is that breaking the connection plug or something? Daz |
23rd Feb 2019 8:16am |
Yes exactly that, a fragile connection that snaps as soon as you look at it! |
23rd Feb 2019 10:25am |
