Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 20 of 38 <123 ... 192021 ... 363738>
GraemeS
The hose attaches to the RH side of the lowest section. It has a clip that must be pressed. The drain plug is towards the back of the sump. It drains a small reservoir for the drain pipe of the primary turbo, which if not drained will over time cause sludge to accumulate.
Post #500026 29th Dec 2018 10:13pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Cheers Cheers
James
Post #500055 30th Dec 2018 9:06am
JST
Well for the RR that has to be the easiest fix, the 2nd oil sump drain was loose....... Cheers
James
Post #500094 30th Dec 2018 3:56pm
Checked my rear o rings the other day
Not leaking still!!! 😁 There is nothing that can't be fixed with a hammer😜😜
Post #500110 30th Dec 2018 5:46pm
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Thanks to all for the great advice on this Thumbs Up As a result did my seals and o-rings at the weekend. Done a full pictorial guide but rather than add to the 20 pages on this thread have set it up on my owners thread, you can find it https://www.fullfatrr.com/forum/post501572.html#501572
Cheers,
Paul. 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #501573 14th Jan 2019 8:32pm
hermarno
United Kingdom 2012 Range Rover Vogue SE TDV8 Alaska White
Hi all, I'm new to the community, just read this post front to back this evening and got completely engrossed in it. I have this problem going on at the moment, leaking down the back of the engine, burning oil smell, smoke arising now and again(usually when I've given it some beans)! i now will be doing the repair myself, basically because of the brilliant info that I've read on this forum tonight. its probably old news for you guys but new for me, so wish me luck and thanks for the guidance. Thumbs Up
Post #501736 15th Jan 2019 8:54pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Welcome to the forum.
I’m lucky to have benefitted several times from those who know way more than me Smile What do I put here then?
Post #501741 15th Jan 2019 9:04pm
hermarno
Thank you sir, I'm a panel tech by trade so looking forward to sharing some of my knowledge in the future when required.
Post #501747 15th Jan 2019 9:34pm
DrRob
My 2011 is having the gaskets done today. Exact same symptoms as you....O rings will be checked at same time Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #501767 16th Jan 2019 7:33am
hermarno
Hi, hope all goes well and the leak identified and corrected. i shall have to wait for a free day, i have started to order parts, hope i can get a cooler on sale or return, be good to have everything on hand should i need it.
Post #501824 16th Jan 2019 7:07pm
mm289
@hermano - the cooler having failed is normally shown by oil in the water of the cooling system rather than a leak which is usually gaskets. So I wouldn't be too worried about ordering up a cooler unless you have symptoms that lead you to believe it has failed Thumbs Up
Cheers,
Paul. 2011 TDV8 AB
Post #501895 17th Jan 2019 1:51pm
dibber83
United Kingdom 2012 Range Rover Autobiography TDV8 Stornoway Grey
Very helpful, I will be checking this next. 2012 4.4TDV8 AB
β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”
2016 Mercedes C350e
2003 TD6 Vogue
2010 Alpina D3 BT
2005 Audi A4 2.0TDi SLine
1973 Series IIa
2001 BMW 320
1996 Audi A4 1.6
Post #502657 24th Jan 2019 2:35pm
Tractor man
United Kingdom 2007 Range Rover HSE TDV8 Baltic Blue
Hi , do you know if this oil leak problem is the same on a 3.6 V8 as my oil leak appears to be coming from the area you are explaining.
Thanks
Post #511949 13th Apr 2019 4:05pm
No its not Tractor Man BUT, the oil filter housing is there and the rubber ring/seal should be changed EVERY service as the heat makes them go hard and flat...
Thats where i would check first sir Thumbs Up
Post #511973 13th Apr 2019 7:48pm
Tractor man
Thanks Craig I will check that tomorrow πŸ‘
Post #511978 13th Apr 2019 8:03pm
