Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 |
Cheers Cheers
30th Dec 2018 9:06am |
Well for the RR that has to be the easiest fix, the 2nd oil sump drain was loose....... Cheers
30th Dec 2018 3:56pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8662 |
30th Dec 2018 5:46pm |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
Thanks to all for the great advice on this As a result did my seals and o-rings at the weekend. Done a full pictorial guide but rather than add to the 20 pages on this thread have set it up on my owners thread, you can find it https://www.fullfatrr.com/forum/post501572.html#501572
14th Jan 2019 8:32pm |
hermarno Member Since: 15 Jan 2019 Location: north yorkshire Posts: 3 |
Hi all, I'm new to the community, just read this post front to back this evening and got completely engrossed in it. I have this problem going on at the moment, leaking down the back of the engine, burning oil smell, smoke arising now and again(usually when I've given it some beans)! i now will be doing the repair myself, basically because of the brilliant info that I've read on this forum tonight. its probably old news for you guys but new for me, so wish me luck and thanks for the guidance. |
15th Jan 2019 8:54pm |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
Welcome to the forum.
15th Jan 2019 9:04pm |
Thank you sir, I'm a panel tech by trade so looking forward to sharing some of my knowledge in the future when required. |
15th Jan 2019 9:34pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 |
My 2011 is having the gaskets done today. Exact same symptoms as you....O rings will be checked at same time Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
16th Jan 2019 7:33am |
Hi, hope all goes well and the leak identified and corrected. i shall have to wait for a free day, i have started to order parts, hope i can get a cooler on sale or return, be good to have everything on hand should i need it. |
16th Jan 2019 7:07pm |
@hermano - the cooler having failed is normally shown by oil in the water of the cooling system rather than a leak which is usually gaskets. So I wouldn't be too worried about ordering up a cooler unless you have symptoms that lead you to believe it has failed
17th Jan 2019 1:51pm |
dibber83 Member Since: 22 Sep 2012 Location: Taunton Posts: 22 |
Very helpful, I will be checking this next. 2012 4.4TDV8 AB
24th Jan 2019 2:35pm |
Tractor man Member Since: 13 Apr 2019 Location: North wales Posts: 2 |
Hi , do you know if this oil leak problem is the same on a 3.6 V8 as my oil leak appears to be coming from the area you are explaining.
13th Apr 2019 4:05pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
No its not Tractor Man BUT, the oil filter housing is there and the rubber ring/seal should be changed EVERY service as the heat makes them go hard and flat...
13th Apr 2019 7:48pm |
Thanks Craig I will check that tomorrow π |
13th Apr 2019 8:03pm |
