![]() | Home > General > What Did You Do In Your Full Fat Today |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
went to London to see the queen ,
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
Found a dirty radiator behind the wheel well cover.
Radiator is now clean. Might be worth checking. 2007 L322 3.6 TDV8 Stornoway |
xjsracer44 Member Since: 30 Nov 2010 Location: Hertfordshire Posts: 274 ![]() ![]() ![]() |
Had wishbone arms replaced to get through 12th MOT at 153,000m as well as full service & was told she’s good for another 150,000 |
Johnniehec Member Since: 03 Feb 2017 Location: A a Posts: 28 ![]() ![]() |
No words needed |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 228 ![]() ![]() ![]() |
Fitted new lower arms.
ptaroni Member Since: 20 Dec 2015 Location: leicestershire Posts: 89 ![]() ![]() ![]() |
Replaced the driverd side inlet manifold due cracking. Cant complain done over 6k with sikaflex holding it together! Only real issue was getting the injector pipes off, the union wouldnt come off 3 off the injectors so had to pull it out with the pipe on on three off the 4 injectors. 5 hours later with plenty of tea breaks wasnt too bad! Also changed a glowplug whilst i was in there, had 8 but didnt see the need to replace 7 working ones as it isnt a big job to change at a later date 2004 td6 l322 - gone Now 2007 tdv8 l322 |
ramigojag Member Since: 29 Oct 2018 Location: Sydney Posts: 17 ![]() ![]() ![]() |
Fitted new camshaft position sensor to bank 1 and a new window regulator in the passenger side rear door. Current:
bruno22rf Member Since: 08 Mar 2018 Location: milton keynes Posts: 69 ![]() ![]() ![]() |
2nd MOT since I've owned my FF - passed with 2 advisories, oil leak and cv boot so well chuffed, also happy to see mileage (my readout is unreadable) - 04 reg now showing just over 85k and, according to the exhaust readout, the engine is running as new emission wise |
Triarii Member Since: 10 Feb 2015 Location: Wess Vinglun Posts: 192 ![]() ![]() ![]() |
Looked at the very, very dirty fatty after I'd gotten out of bed at silly o' clock (day off) to take madams SL in for a horrendously expensive service at the main stealer whilst she snoozed on. To be fair she didn't get in from work until 2000hrs, after leaving the house at 0630. Now about to hit the M4 and anticipate the joys of the south circular at the end...….. |
Cheekyfox Member Since: 21 Dec 2018 Location: Schliersee Posts: 8 ![]() ![]() ![]() |
Fitted a new gear lever surround, now have a Hill Descend switch... and it works. |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Went to look at the view at dusk
Previous: - 2004 FFRR Vogue 4.4 V8 with LPG 1997 P38 4.0 SE with LPG 1997 P38 4.6 Vogue with LPG |
Redbaron Member Since: 23 Oct 2018 Location: Wales Posts: 8 ![]() ![]() |
Realised that my car is hanging.com
Gave the old girl a wash as she was looking a bit grubby. Having thoughts about selling it, I only need a tow car for my track car and the full fat seems a bit wasted for that purpose. |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 792 ![]() ![]() ![]() |
Top bush,rear, on both sides replaced...bye bye to the pram like squeak ! Rear brake overhaul thrown in as sliders where a bit sticky. Then off to Kwik Fit for a 4 wheel adjustment package. Feels like a new car although I think a front droplink might be suffering a bit of wear. |
