Home > General > What Did You Do In Your Full Fat Today
Page 288 of 381 <123 ... 287288289 ... 379380381>
matlandy
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Got my IID Tool BT in the post Monday just set it up today, and enable my park heater hopefully this will work as the weather is getting colder. Smile
Post #496210 21st Nov 2018 5:27pm
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
All brake lines replaced and mot booked for half one tomorrow.
I’ll be keeping fingers crossed Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
59 MY2010 Range Rover Vogue L322 3.6 TDV8 Zermatt Silver
53 Range Rover Vogue L322 4.4 V8 Java Black
98 P38 Range Rover 2.5 DSE Champagne Gold
Post #496292 22nd Nov 2018 3:58pm
Gsxr1250dave
Swopped out the cam cover gaskets found a coolant leak, replace air and pollen filters darkness stopped play engine oil and filter tomorrow stat mod left to do. Happy days don't trust your mechanic remember I bought this car as spares and repair original owner broke down on the m25 with low coolant warning topped it up broke down again got recovered home his mechanic who has been servicing the car for 3 years diags head gasket failure. If the mechanic who had previously nipped up the cam cover bolts on a service a year ago had done the job properly he would have found the Coolant leak in the 1st place.
I'm very happy so far Very Happy Very Happy
Post #496422 23rd Nov 2018 6:37pm
Gsxr1250dave
227 mile round trip on one tank of gas at £48 so 21 ppm I'm a happy bunny
Post #496899 28th Nov 2018 4:10pm
Gsxr1250dave
Carried out the 80 degree thermostat mod and coolant flush and refilled with corret pink type with the help of my mate john a wizard on these engines.
Post #497062 29th Nov 2018 7:49pm
Gsxr1250dave
Serviced the lpg seems the filters have not been changed in 46k miles just the engine oil and filter left todo and the engines serviced.
Post #497174 30th Nov 2018 9:31pm
ptaroni
Removed and replaced injector copper washer on cylinder 8 due to blowing by! Wasnt as bad as i imagined, injector would not budge, cracked the bolts off and started it up, gave it some revs until it got louder and louder then managed to wiggle it out! Recut the seat and fitted new washer , ran it up for 10minutes and retightened bolts then rebuilt. Someone has already been there as injectors have been numbered with tippex! 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #497368 2nd Dec 2018 9:33pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Oil and filter as 7k since last change. Would the designer who added the extra sump nut under the cross member on the TdV8 3.6 please have the guts to own up and tell me WHY there and why so %$%& to get at ?
Post #497478 3rd Dec 2018 8:44pm
crowebeard
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
After 18 months of a blank instrument cluster, managed to get it sent off this week and repaired. Refitted today and can now see I've done a lot more miles than I thought I had. Now on to the brakes.... David
2012 Range Rover Westminster 4.4TDV8
2004 Range Rover Vogue 4.4 V8 (LPG) (Not quite gone)
2021 Mazda CX-5
2003 Porsche Boxster
Post #497852 7th Dec 2018 5:30pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Popped in a new carbon activated pollen filter, bought in the sale at ECP - saving £30 over a boggo LR one Laughing Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #497858 7th Dec 2018 6:15pm
DaveK
Xray charlie wrote:
I fitted new arms & lower ball joint to my N/S/F suspension, going to do other side tomorrow.
Coincidence ! with the help of a good friend and mechanic, did both sides yesterday.Had to resort to fire to heat the bit where the new ball joint ' just slides in " in order to get the old ones out. Who would belive that corrosion was such a good glue. Wished they'd inc new bolts with the ball joints though as they where in pretty poor shape by the time they where removed .
Post #497864 7th Dec 2018 7:00pm
Huwrhys
United Kingdom 2017 Range Rover Autobiography SDV8 Loire Blue
So it was my Daughters 27th birthday and as a surprise we booked Disneyland Paris for the weekend. We drove from home at 4:00am and got the Eurotunnel across the channel. All very nice in a FF tbh and then I got a warning that my OSR tyre was low. I pulled over to put some air in and discovered I had a puncture. Took me about 20 mins to swap the wheel but couldn't see anything which may have caused it. Today having returned after an incredibly expensive and wet weekend I was told it was fatal. A new tyre is needed just to add some further expense to the mouse weekend.
I must say I'm now no longer interested in queueing for an hour for a two minute ride or buying four burger and chips with extra onion rings for £100. I have donated far too much to the little rodent over the years and it has come to an end.
Very impressed with the FF and the TPMS. Thumbs Up
Post #498114 10th Dec 2018 5:37pm
smartymarti
United Kingdom 2014 Range Rover Vogue SDV8 Corris Grey
Today I had a few simple tweaks and think it makes it a lot more current imo
Post #499533 23rd Dec 2018 7:12pm
ptaroni
Applied more sikaflex to drivers side inlet manifold today. After probably 6k relativaly trouble free miles apart from a precautionary battery change due to baby being due... saturday evening rushing the other half to hospital in labour a sudden 'bong' and engine system fault ... calmly pulled over and restarted engine and all appeared normal until hitting 2500 rpm then a noticeable loss of power under load so used the gearbox in manual to keep the engine under minimal load and managed to limp half an hour to the hospital! Dont know what was more scary, birth of my first child or how much the repair would be! Baby boy born 1.56am nice and healthy 7lb 10z and then checking the manifold finding the crack and the relief! Funny thing is i have a new manifold ready to fit since last time just havent got around to fitting it!! 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #499602 24th Dec 2018 7:15pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Congrats on the baby Thumbs Up
Post #499622 25th Dec 2018 1:11am
