Home > General > What Did You Do In Your Full Fat Today
Page 289 of 377 <123 ... 288289290 ... 375376377>
nearlee
Wales
Fitted new stoppy things to the front, and blanked egrs using hendas thread in the wiki Thumbs Up
Pic of stoppy things won't upload, gone with ebc green stuff pads
 Remember:- amateurs built the ark
Proffesionals built the titanic
Post #500191 31st Dec 2018 2:19pm
went to London to see the queen ,
whilst there i hit a kerb that was unseen,
now i need to source new wheels,
and shall be looking for some deals.....
Post #500295 2nd Jan 2019 9:04am
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
Found a dirty radiator behind the wheel well cover.
Radiator is now clean. Might be worth checking. 2007 L322 3.6 TDV8 Stornoway
Post #500312 2nd Jan 2019 10:32am
xjsracer44
United Kingdom 2007 Range Rover Vogue SE Supercharged Java Black
Had wishbone arms replaced to get through 12th MOT at 153,000m as well as full service & was told she’s good for another 150,000 Very Happy
Post #500313 2nd Jan 2019 10:34am
Johnniehec
No words needed
Post #500480 3rd Jan 2019 11:10pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Fitted new lower arms.
Discovered I have an oil leak down the side of the radiator and I need to do the front ball joints. Sad
Post #500665 5th Jan 2019 5:17pm
ptaroni
Replaced the driverd side inlet manifold due cracking. Cant complain done over 6k with sikaflex holding it together! Only real issue was getting the injector pipes off, the union wouldnt come off 3 off the injectors so had to pull it out with the pipe on on three off the 4 injectors. 5 hours later with plenty of tea breaks wasnt too bad! Also changed a glowplug whilst i was in there, had 8 but didnt see the need to replace 7 working ones as it isnt a big job to change at a later date 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #500769 6th Jan 2019 4:06pm
ramigojag
Australia 2003 Range Rover HSE 4.4 V8 Ipanema Sand
Fitted new camshaft position sensor to bank 1 and a new window regulator in the passenger side rear door. Current:
2003 Range Rover V8 HSE
2014 BMW 125i
Previous:
2005 VW Golf GTI
2001 BMW E39 M5
1991 Peugeot 205 GTI 1.6
1995 Range Rover P38 4.6 HSE
1991 Suzuki SJ413
Too many others to mention
Post #500822 7th Jan 2019 4:59am
bruno22rf
England 2004 Range Rover Vogue 4.4 V8 Java Black
2nd MOT since I've owned my FF - passed with 2 advisories, oil leak and cv boot so well chuffed, also happy to see mileage (my readout is unreadable) - 04 reg now showing just over 85k and, according to the exhaust readout, the engine is running as new emission wise Very Happy
Post #501082 10th Jan 2019 8:25am
Triarii
United Kingdom 2017 Range Rover Autobiography SDV8 Corris Grey
Looked at the very, very dirty fatty after I'd gotten out of bed at silly o' clock (day off) to take madams SL in for a horrendously expensive service at the main stealer whilst she snoozed on. To be fair she didn't get in from work until 2000hrs, after leaving the house at 0630. Now about to hit the M4 and anticipate the joys of the south circular at the end...….. Very Happy 17 MY Corris Grey 4.4 VAB
Silver MB R231 SL350
Post #501195 11th Jan 2019 10:17am
Cheekyfox
Germany 2004 Range Rover Vogue Td6 Zambezi Silver
Fitted a new gear lever surround, now have a Hill Descend switch... and it works. Very Happy
Tried out the IID BF tool from Dan, it works, cleared all the existing faults and now only have to sort out a broken passenger side heated mirror.
Also enabled the Park heat function...just now need to get the fbh to work Wink 'Weginald the Wange Wover"
2004 L322 Vogue TD6
Previous LR:
SIIA Safari 2.25 LPG 'Larry'
Post #501224 11th Jan 2019 3:09pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Went to look at the view at dusk
 Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #501317 12th Jan 2019 5:02pm
Redbaron
Realised that my car is hanging.com
Embarassed
Post #501319 12th Jan 2019 5:26pm
Jamiehol
Gave the old girl a wash as she was looking a bit grubby. Having thoughts about selling it, I only need a tow car for my track car and the full fat seems a bit wasted for that purpose.
Post #502243 20th Jan 2019 8:50pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Top bush,rear, on both sides replaced...bye bye to the pram like squeak ! Rear brake overhaul thrown in as sliders where a bit sticky. Then off to Kwik Fit for a 4 wheel adjustment package. Feels like a new car although I think a front droplink might be suffering a bit of wear.
Post #502316 21st Jan 2019 7:06pm
