![]() | Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
It's been a while, I've had a US-sourced Ford Mustang heat/cool unit sitting there, together with a brand new foam base, ready to attack and fit to get my drivers seat base working....
....well you're absolutely right John. The main seat pad has channels grooved into the moolding. Into those channels sits a folded foam ducting piece, then a soft foam topper with holes that let the air through: ![]() Mine has totally collapsed. The whole thing is squished, distorted and a mess. This seat's done over a 100k miles. Inside the ducting was worse, the 'roof' of the main chamber, the bit inside the hole you see had completely caved in too. You can't see that in the photos but the air had absolutely no chance of getting directed along the ducting. That's what's killed the heat/cool unit. No doubt causing an overheat. Once I realised I only had one of three pieces I'd really want I phoned Dan and the ducting and the foam topper, which don't come with the seat foam, cost another £130. (the duct is £75). But Dan didn't have in stock and, this time of year, it'll be a week before I could get either. So I started a repair. Here's the new vs old. First step pull apart these three pieces and discard old seat base: Then pull away the topper from the duct, I need to get to the collapsed roof: Next I made a new roof from a plastic food box. It's oven safe so I figure can take a good amount o heat. Roughed it up with 80 grit. Note the crease I put in it, you need that because the seat cover has an attachment pipe sewn in which needs a recess. This material is more rigid than normal. I tested it to see if I could feel it. I need something stiffer, but this is a soft seat. I don't want something hard down there! It seems good. It's flexible but rigid enough and there are enough soft layers on top of it: Here it is in place, glued in with contact cement: Turning it over, I now need to try to re-shape the opening. I got a water bottle and stretched it in to use as a former. Then I got a blowtorch, and heated as much as I dared: The plastic water bottle melted but the ducting took the heat ok. It seems to have worked and it holds it's shape now: This chamber takes an 80kg hit every time I sit on it. That's why it collapses over time. One of the ducts still looks a bit crushed, plus I'm wondering what I can do to stiffen up the camber. I'll not want to add anything rigid there.... I have a bit of glue still drying so can't reassemble it yet. Turning it over, there is now a clear channel for the air to travel through A bit hard to see from this pic but million times better than before: Next step, refit the seat cover, not looking forward to the hog rings... Then: adapting the Mustang heat/cool unit. Stay tuned. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway Last edited by GGDR on 29th Dec 2018 9:57am. Edited 1 time in total |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Brilliant work Greg |
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 ![]() ![]() |
Fantastic info Greg - really interesting/useful to see how the air is ducted through the seats like that.
Thx Bushy30.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Excellent write up Greg, thanks, |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
+1 Greg.
Thanks chaps.
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 100 ![]() ![]() ![]() |
Did you try testing your original base heater with the squashed ducting disconnected ? Trying to ascertain if your Peltier unit is dead or just shutting the system down due to no air flow . |
Yes I did test the unit off the seat (but still wired in) before I started. It'll run for around a minute then shut off.
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
Inspired by your success, I've had a look at my non-functioning heated/cooled front seat.
Hi Steve,
Another note: John W has kindly checked my (ducting) repaired unit.
Been running the Mustang butt warmer for a couple of days on my short commute to work and back.
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 ![]() ![]() ![]() |
Does all seem to be ok now with the Mustang replacements?
